Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • If any devs are interested here's a 3.4 log. I have a couple days free I'm gonna do more... also compare with 3.3 in loiter. Seems like it's not as good in loiter / pos hold as 3.3 but hard to tell with just 3 flights.
    47.BIN.zip
    https://storage.ning.com/topology/rest/1.0/file/get/3702140747?profile=original
    • 3.4 When I did do auto tune it only did pitch for about 2 minutes. It never did roll or yaw and even the pitch was very short. Also http://ardupilot.com/forum/viewtopic.php?f=82&t=14544
      • I take it 3.4 is only something for the brave to try at this point? While I do have a test quad for experimenting, a death wish for Dixie Cup is not desirable :)
        • Yea probably not the smartest thing I've done flying pre- beta.. But  I've been very keen on boat mode and it seems they have that worked out.
          [MAV 001:1] APM:Copter V3.4-dev (f60f0e80)
          [MAV 001:1] PX4: 546f2064 NuttX: d48fa307
          [MAV 001:1] Frame: QUAD
          [MAV 001:1] PX4v2 0036002D 30345101 37383933
          I went through 4-5 batteries with no issues in many modes.
          The only thing I notice is it takes longer to arm. A couple times I got some weird stuff.... 'new home location'....Sounded off on Tower even though I had 18 sats at the time. One time I did RTL and it went 1000 feet from where it should have. cmmmmmm who knows... but never any stabilize issues.
          • Been flying 3.4 in all modes no issues! Very windy here... opps... I mean a very nice tropical breeze. lol And it handles the wind no problem. Very nice! Meanwhile... my brother with a phantom dipped his go pro and 3 axis gamble in the salt water by accident ... it's toast. It's the 3rd time he's crashed because of the 'smart' battery. It starts to not maintain altitude to warn you of a low battery but it IS NOT without it's mishaps. His battery had ample power the FW makes the mistake and it's cost him plenty. PLEASE devs don't over think the smart battery in the solo. Don't over engineer it like the phantom. Let the pilot decide what's needed. In my brothers case it stopped holding altitude with the sprung center stick. By the time you notice with fpv over water it's too late!  No issues for me with e 3dr pixhawk :]
            3702855074?profile=original
            • COOLL!!!
              Your brother definitively need a good copter ;) with Pixhawk
    • Any status update on "boat mode" ?
      (see discussion earlier in the thread, or just search the site for "boat mode" )
      • re-boat mode- It's my understanding it will for sure be in beta 3.4 probably in January.  I tested what they had so far and it worked perfectly!!
        • Great. Thanks.
  • I attempted to upload 3.3.2 coming from 3.3.1 and the upload completes fine.
    But when the "please wait for musical tones to finish before clicking ok" pops up I do not get any musical tones even after several minutes.
    The hawk board won't connect to mission planner or do a start up cycle when the battery is connected. The small lights flash, but the large led stays dark.
    I have tried using different USB cables and tried loading ardu plane also. Each time the up load completes but no musical tones.
    Using the latest MP 1.3.32.13.
    So how do fix this?
