Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hello,
i have a small tri running 3.3.2.on a pixfalcon. Flying in stabilize or pos hold there is always a small drift in yaw. Even when i keep the stick centered, it slowly turns.
Looking at the logs i found that the DesYaw also drifts and the tri follows quite well. Where does this drift in DesYaw come from?
2016-02-02 16-13-35.bin
By the way, Leonard's done some work on the TriCopter "stability patch" for Copter-3.4. It has a number of improvements including reduced throttle-vs-yaw coupling and better prioritisation when it hits the upper throttle limits meaning you should get better maximum vertical acceleration.
We have a bit of a shortage of TriCopter pilots so I hope you can help us test when the Copter-3.4 beta becomes available.
HI Hubertus,
One thing I forgot when I was talking to Randy. I dropped RATE_YAW_FILT_HZ to 2 Hz and that made all the difference for my tri. So I would suggest trying that first.
Hubertus,
One answer is the desired yaw can be dragged around by the actual yaw if it strays more than about 10 degrees. There's some argument about whether that's too small an error to lead to the dragging but.. in any case, that's why you're seeing the desired yaw drifting.
I had a chat with Leonard and we think it's primarily a tuning issue. If we can get the control better then the desired vs actual will stay closer together and the dragging will stop.
It looks like the tail servo is oscillating (see blue line below). Leonard suggests reducing the RATE_YAW_P and RATE_YAW_I by 50% and keep doing that until the oscillations go away. RATE_YAW_P is already low at 0.08 but try even lower like 0.05. RATE_YAW_I is currently 0.015 so maybe try 0.01.
He also suggests keeping STB_YAW_P low (it's 4.5, don't raise it).
Hi, I get the bad accel health quite a bit in the colder weather. I've read Dmitry's thread and I'm not sure its the same problem as the sensors discharge issue. I see good data from the imu2 accelerometers when indoors, then I take it out where its cold and within 5 minutes imu2 goes bad. Then I can bring it indoors again and it'll start working. I've disabled the prearm checks for INS (then tried disabling all of them), and also have ins_use2=0. If I can manage to arm, it flies fine. But getting past that hurdle is sometimes difficult. I've found a workaround, to power up inside where its warmer then take the MR outside and arm/fly before the lsm303d goes bad (but sometimes this is difficult as the GPS needs a minute or two to lock in). Is there any way to disable the bad accel health warnings and ignore the lsm303d completely besides downgrading to AC3.2.1?
Randy / devs
Is 3.4 gonna be released for testing anytime soon or is that sort of in flux?
Richard,
The motors rework has taken a little longer than expected which is why Copter-3.4 hasn't begun beta testing yet. There's also another important decision that needs to be made which is do we include any/all of these features in Copter-3.4 or push them off to 3.5?
I'd say each one of these features will consume about 1 extra week of dev.
I'd have to say I'm highly motivated to test out any feature for terrain following! I've got a few laser altimeters, but open to trying new sensors as well.
take the week + to get it right. Pushing out new versions for the sake of pushing out new versions is never a good thing. Take the time to write it correctly. 99% of us can wait a few weeks before a new version. I personally would rather wait a few months and get a well written code base then to have these things churned out week after week and having to deal with any issues that arrive with them. I'd go so far as saying a new version every 6 months is almost too much too fast.
That's not to say bug fixes could not be released on a fast ring, but I'd much rather see new "versions" released on a much slower and defined "slow ring" :)
Randy,
Should we expect SF10/C support for I2C in the next firmware release,
if so, you wouldn't know the estimated release data?
thanks
29
30
31
32
33
of 449 Next
