Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Also cheap USB cables can transfer EMF
  • re throttle stick mid position,  sprung vs un-sprung?
    I wonder what the general consensus is for what people now use and prefer for the throttle stick and whether to have it spring loaded so that it sits in the middle (hover position) compared to having it un-sprung as we used in the past.
    I can see the advantage for the sprung version that it helps to keep a good stable hover at altitude where you can see it clearly.
    I already have this of course on my DJIs. So I want to try it out on my Pixhawk and APM2 rigs, but would be interested first in people option, experiences and of the pros and cons of this?
  • I'm installed the Lidar Lite v2 on my cuad following instructions, I check in mission planner and sonarrange value is working but when flying, I hope, the copter still use the baro readings, I try to change some params but not luck and couldn't find the issue, or any mistake with params I did, or something with connections, the second log, a windy day, appears an ERR 0-249 , I couldn't find what means in instructions. In third log sonar alt appears but didn't work too. Someone can help me?
    53.BIN
    54.BIN
    52.BIN
    https://storage.ning.com/topology/rest/1.0/file/get/3702213128?profile=original
    • This from 52 log, looks horrible
      3702625003?profile=original
  • hi randy, i don't see any amp copter 3.4 in mp and apm 2 ? i have install update mp and apm2.
  • Parachutes not responding as usual in previous versions.  Posted this in another forum (wrong one).  Setting up dual chutes are a large unit, but ran into some odd behavior during testing.  Set the min alt to 0 and tried manual deployment in stab, alt and loiter modes with all working perfect.  But auto deployment is a roll of the dice.  Same thing in all three flight modes.  Tip the unit over and either it will say "detected crash" or "parachutes deployed".  Both kill the motors which is good, but "crash detected" doesn't release the parachutes which would be really bad lol!  Strange.
    • Curious if you are testing the auto deploy while flying or on the ground? Looking through the code, it appears the parachute won't deploy if the telem reports landed=true, in the c++ source "if (ap.land_complete)",
      It also records the barometer readings, and skips the deployment if the readings increase. I see a todo note in the code to check if its actually falling.
      I wonder if the barometer check is the source of your issue. Watching the barometer on several of my pixhawks, the readings fluctuate. Maybe "random noise" from the barometer is affecting the performance?
      • Testing on the ground, so good point about the barometer.
  • I'm installing A Lightware SF30/B Sonar on my Pixhawk, will APM work OK ?
  • I'm not getting any Bata versions showing up on the MP after clicking "Beta firmwares" .
