Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Randy is right as usual, but he is a brave man ;-)
I am not and would like a calm controller...
I sent you reply in the other thread: too much Y vibrations.
Here is my S900 with AP3.3 on Pixraptor in "War of drones ;-)"
I have the inverse problem: have to lower rpm.
I want to fly with 6S LiPo instead of 4S to get some more minutes of flight with the same setup.
The hexa rocketed over 200 meter into the sky with the 6S LiPo :o (after 5 minutes I managed to land in LOITER but it likes a slow motion landing because of the higher revs)
o_o
Question: Will AUTOTUNE solve this in a way or should I set to all minimum THR_MID and THR_MIN ??
I worry another rocket start and still feel unsure to try again :/
Dear randy and all friend.
i have check fly with 3.3.3 fw 1gps and my drone is work fine. but after use 2nd gps neo 8m. Problem when i take off it's good. but after some second my quad is going down and up. i'm trying to land and it's said Compasses inconsistent. so can't fly anymore, but after home, i try to connect again, and all are fine. don't know why, maybe interference somewhere ? logs is below.
my quad : 3dr pixhawk, 3dr gps lea6, 2nd gps neo 8m. motor air gear 920kv.
Thanks all.
2016-05-08-17-14-58.bin
I have been running 2 GPS on mine for months, not a single issue. Ran them on 3.2.1 and now on 3.3.3
You can't have both GPS be same exact model, one if them has to be better than the other, I run and M8N and a 6M....no problem for me, the M8N is always the primary with lowest hdop. If you have them both same then it will flip back N forth between them and get sudden position changes.. You don't even seem to have a GPS issue but a compass issuu, you definitely can't run two external compasses
Remove the 2nd GPS. There are still issues with 3.3 and 2nd GPS modules.
thanks you. i will. can i backup to 3.2.1 and use 2nd gps ? or 3.3 ?
You need to wait for 3.4 from what the devs have been saying.
Been trying months off and on to get my quad tuned properly, autotune results create high and violent oscillations that my gimbal cant compete with. Tried lowering in all sorts of combinations the stab and rate pids, with little success, I either go from it feeling like a feather with the littlest bit of wind, or it having violent oscillations but more locked in.
It is a bit over powered, but i've already adjusted the throttle hover, based on what i saw in the logs.
Also after tuning, all motors behave weirdly, if its on a flat surface, all spin up at the same time, but if theres a slight slant eg, its leaning to the left, only motors on the left spin up, right side doesnt move, till I raise the throttle.
I use an alien 680mm frame with 15 props,
ztw 4oa esc's flashed with blheli( had synce issues with simonk)
heres a link to my last flight logs.
https://www.dropbox.com/sh/i4vqz33pi00yql0/AACS4NIW5FoZ4rrWbPN9z3AC...
