Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I tried 'Follow Me' tonight. The quadcopter was quite jerky when adjusting it's position relative to my location. Is there a new setting that makes for more smooth yaw etc. when using 'Follow Me'?  This was after a new Auto Tune on rc5.
    In Basic Tuning there is a slider for pitch/roll sensitivity. Would sliding that left make things smoother?
  • I did a few more tests with rc5 and the RCMAP changes. RCMAP works great as reported elsewhere. Couple of things I noticed:
    1. I cannot arm in Auto. GCS says "Press safety switch" but the switch is already pressed!
    2. If I arm in another mode, switch to Auto and then try and run a mission starting from the ground, when I raise the throttle the copter immediately heads towards the first waypoint from the ground, rather than climbing to a safe distance and then heading towards the waypoint. I was in long grass and cut a swathe through it before it got to a safe height!
    I've not tried either of these before so not sure if they are new to 3.3, but both seem like bugs.
    • hi got no problem with 3.3rc5.on auto. i normally put takeoff on the first line and set the altitude and loiter time. succeeding lines are waypoints. last line is rtl
  • Not sure if there was an intended change in arming check but it appears that the safety switch check not always performed.
    RC5: in loiter GPS lock but compass issue (indoor testing), I can arm before enabling with the safety switch (ground station indication "armed") and due to EKF variance  it immediately switches to LAND mode. So actually the FC interprets the status  as ARMED too. Motors are not spinning - so the switch still does its job.
    • Do you have compassmot enabled ? if yes try to disable and restart this could solve the ekf variance error.
      • Actually I don't have any problem with it (only temp due to indoor conditions) but I do not think that Pixhawk should arm without the safety switch enabled.
  • i'm facing a strange behaviour and i'm hoping somebody can help me out.
    i have always an error message on the flight screen saying something like "GPS variance". Normally the error can be surpressed by disabling check_ekf_tresh. But obvious this is not the solution. This behaviour can lead to unwanted yaw rotations during take off -> pixhawk tries to correct the deviation which in reality is not.
    what i noticed today is that the yaw heading is turning slowly counter clock with the copter sitting on the ground and not moving just sitting there. The deviation is growing more and more after a couple of minutes i have an deviation in yaw greater  than 180 degrees.
    Then i disabled compassmot just to see if this makes a difference and this solved the problem. i just set "COMPASS_MOTCT" to 0.
    this startet with fw 3.3
    Can somebody explain this ?
  • Whould it be possible to add a small delay, when Pixhawk is expecting new firmware, before it proceed to wake-up?
    The problem I have is a competition between the laptop recognizing the USB and Pixhawk booting up. Sometimes it requires many attempts to flash new firmware with Mission Planner.
    The stationary, also running Windows 7 Pro 64-bit, recognizes USB quicker and usually manages to flash.
    I guess I'm not the only one having this kind of problem.
    Anders
      Please keep in mind this discussion is for copter testing.
      Are you using Mission Planner in A virtual machine?
      • No! This happens every time I try to upload new firmware to my copter, or any other Pixhawk.
