Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • I do not follow. I asked how did you get battery failsafe to work, if it works. As it does not for me. Not sure what ground station got to do with it, does it make any difference? All i want is for drone to initiate RTL when battery voltage drops to 13.9v.
                Paul,
                It's still on my list to figure out why this isn't working for you.  My guess at the moment is that the battery failsafe is triggering before arming and then it's not being reset.  I've looked at your logs but not in enough detail to understand why it's not working.
  • just a question, is it possible to turn pixhawk in a full 3D copter ?
    From mechanical view, ESC's which can turn direction and symetric props are given.
    • for the naze32 there seems to be a setting which needs to be set to "3D" and go
      • 3D flight is more suitable for mini Vbar……
    • Fully supports traditional helicopters, but whether it can support 3D aerobatics Helicopter, I did not dare try it !
  • Can anyone confirm to me than the new Landing gear retract function works ?
    I have a new frame with retractable landing gear, have followed the wiki page about this function but can't get it to wrok.
    I haven't flyed yet but I try this function on the ground, Can anyone confirm than this feature work or not ?
    I've only found this input : https://github.com/diydrones/ardupilot/issues/2304
    Thanks community :)
    • On RC5 that works fine ;o)
      Regards.
      Alberto
      • Hey thanks for your reply .
        Can I test to retract without arming for testing purpose ? Cause I have all connected and configured my ch8 but nothing happened on the ground. I haven't flyed with this new frame yet
        • Sure you can.
          As I have a Tarot650 Sport sitting in it's bag with gear up, the first thing I do when I connect a battery is gear down without arming.
          Also, the first thing I did was to connect the gear directly to the receiver to be sure it's working OK.
          I did had some problems, as the manual was nonexistant, but after I sorted that out, it was easy to set them with 3.3.
