Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • We are getting closer to final...uploaded..one question;c) full rate IMU logging for improved vibration analysis (set LOG_BITMASK to All+FullIMU)..my LOG_BITMASK is now set to 176126(there is no explanation for that number)  and I cant see what is number to be set for All+full IMU...one closest to that is 958 -Default+IMU or 43006 Nearly All...Should I leave it to 176126?
        Emin,
        MichaelO has made it easier to see what's enabled/disabled with the latest version of the MP.  If you go into the Config/Tuning, Standard Params hopefully you'll see the individual items are displayed now so you don't need to rely on the drop-down.
        3702706257?profile=originalIt would be nice if this selector was moved to the Flight Data screen's Dataflash tab but.. one step at a time I guess.
  • Is this related to 3.3 beta?
    I'm trying to get an OSD working, and trying to update "SR1" parameters, and they do not save.  I found some older posts about that, and APM planner being the issue.  I am using the newest mission planner and copter 3.3rc5.
    I've been fighting this for a couple days now, and finally decided it's time to start asking questions :(...
    thanks
      Scott,
      I guess the OSD is connected to Telem1?  And is the GCS also connected to Telem1 (maybe through a 3DR radio or similar?).  I'm not sure what the issue is but I can imagine two possible causes:
      1. the GCS is overwriting whatever you put into those parameters because it is also connecting to Telem1 and telling copter (using the SR1_ parameters) what data and rates it would like.
      2. you're trying to set the SR1_ parameters to a value they're already set to (i.e. it's "2" now and you're trying to ensue it's always "2" even after a reboot).  It won't let you save unless the value is changed.  I.e. change "2" to "3" and then save it.
      It's very possible neither of these is the issue but it's all that comes to mind and I'm expect you've already seen the wiki.
      • Yes, OSD and 3dr radio on telem 1 w/ y cable.  Tried updating the settings while connected via USB and through the modem.  Been through the copter wiki and osd wiki.
        BUT, since a bunch of people didn't say "yes, my OSD is broken too" I won't waste your time in this 3.3 section.
        Otherwise, auto-tune and all the flying I have done on 3.3 is working great.  thanks!
        • I have minimOSD on armattan and it works fine with both rc5 and rc6.
          saying that - in all cases it was feeding from serial1 telemetry port. I could not make it ever work from serial2.
          OSD should have only RX connected, no TX output from OSD should be used. connect 3DR radio to same telemetry feed, both RX and TX and RTS/CTS also - it helps. then it should be work every time and will be quite reliable.
          swap serial2 type parameter to 5 from 1 - it will make serial1 work all the time. I attach gps unit to serial2 and to serial3 and this configuration seems to be problem free.
            I've actually never used an minimOSD (or any other OSD) but I think if it's sharing a telemetry connection with the radio then what Paul says is right about disconnecting the minimOSD's tx line so it can't interfere with the radio<->GCS communication.  If the OSD is connected to a separate telemetry port it should have both TX and RX connected so that it can tell the FC what data it wants (and at what rate).
            Ah, also I suspect the minimOSD wants the buad rate to be 57600 so the appropriate SERIALX_BAUD parameter should be set to "57",
  • Hi, I wonder how long it can take autotune process? a 450 cuad after 18 minutes and he had no battery and the second attempt 15 minutes and never finished. :(
    Sorry for my English
    attach the log
    19.rar
      Hi Jose,
      I can't download your logs but 15 minutes isn't unusual depending on your tune and how many times you had to reposition. Yaw especially can take some time but that has been improved in rc6.
      As people have already told you, you can tune single axis at a time.
    • I had the same problem on a 450.  Solved it by doing autotune on pitch and roll, only, on one battery and yaw on another battery.  You can do this by setting Autotune_Axes parameter according to the following values:
      VALUE MEANING
      7 All
      1 Roll Only
      2 Pitch Only
      4 Yaw Only
      3 Roll and Pitch
      5 Roll and Yaw
      6 Pitch and Yaw
      Good luck
