Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • That makes sense.  I was hoping a dev would get back to me.  The condition for using 3.3 is written as
        #if HAL_CPU_CLASS < HAL_CPU_CLASS_75
        # error ArduCopter ver3.3 and higher is not supported on APM1, APM2 boards
        #endif
        which I was hoping meant that flymaple was ok.  I'm making my own board and I have the same chip as flymaple.
          Jared,
          Thanks for finding the specific compile issues.  This is more of a dev question so it'd be better to bring it up on the drones-discuss email list.  I think we just don't know if the EKF will function on the FlyMaple (and similar).  If it can run the EKF at 400hz then we can easily modify those #if lines that you've found so that it compiles for the FlyMaple again.  If the CPU isn't up to the task then I'm afraid we will be forced to drop support for the board and I'll modify the #error message so it pops up the failure for anything with CPU_CLASS < 150.
          The timing on the board can be seen by looking at the dataflash log's PM message.  There's a number of long loops and maximum loop time.
        • T3
          Jared,
          I have no experience with flymaple, but if your board is HAL_CPU_CLASS_75 then the error message is correct since APM:Copter 3.3 does not support APM2 boards any longer due to EKF and you should look for the 3.2.1 branch which should work.
          Best regards,
          Thorsten
          • The APM boards are HAL_CPU_CLASS_16, not 75.  Config.h explicitly allows cpu class 75 for v3.3, but the code wasn't written with that in mind.
            I'm just curious if they meant to allow it, and then didn't take care of it properly, or if it wasn't supposed to be allowed in the first place.
            Thanks!
          • I didn't get an error message; I got a compiler error.  config.h says that class 75 is ok to run 3.3, but the code wasn't written to support it.  I'm just curious which was the error.
  • Hey guys.  I have one "bug" for you, and one question.
    1) Drift mode seems to have lost it's altitude hold. In 3.2, drift mode was modified to include Alt Hold which is awesome. Its a great model for aerial video due to the smooth "coordinated turns".  But it seems to have rolled back to the old version of Drift mode where Alt Hold is not in place.
    2) This may be elsewhere in the thread, but I can't find it in 190 pages.  Are there parameters I can change to speed up the auto tune process? I realize this may sacrifice some precision. But it's ineffective right now when the battery gets too low to continue.  Can I speed it up, or do one axis at a time or something?
      Thanks Edwin and Henri!!!
    • Thanks. I'll use those features and probably do it one axis at a time.
    • @Pedals2Paddles: Yes one axis or combination of axis if your battery can handle long flights..
      In mission planner from the complete tree open the autotune tab and set the axis you want as follow:
      Autotune Bitmask: 0:Roll,1:Pitch,2:Yaw
      VALUE MEANING
      7 All
      1 Roll Only
      2 Pitch Only
      4 Yaw Only
      3 Roll and Pitch
      5 Roll and Yaw
      6 Pitch and Yaw
    • You can do one axis at a time or a combination of them:
      http://copter.ardupilot.com/wiki/configuration/arducopter-parameter...
