Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • OK, it does not seem to be so.
        is the 'Connected=True' message in the MP status window referring to USB connection specifically?
        mine is not connected to USB and it stays as 'true'.
        What is expected from
        return stm32_gpioread(GPIO_OTGFS_VBUS) && stat("/dev/ttyACM0", &st) == 0;
        this to happen? what is the 'stat("/dev/ttyACM0",'? Does it need any hardware modification on the AUAV board or not?
        • if it matters or no, here are start messages from MP, below. Was it expected to identify AUAV in there somehow?
          APM:Copter V3.3-rc8 (818ef282)
          PX4: b0cb142b NuttX: d447403a
          Frame: QUAD
          PX4v2 0025002A 3333470F 39323135
          PreArm: Need 3D Fix
    • 3702582415?profile=originalRandy,
      I just flashed RC8 and tried to initiate battery voltage return. It did not work.
      this last log had it with reserved MAH amount set to non-zero
      https://www.dropbox.com/s/8jzwoii6uykua2d/8.BIN?dl=0
      this first has it with voltage only set and reserved mah at 0. voltage for RTL was set to 15.4 and it flew past it, I then reduced it more, disarming and arming drone, no use, it acts as before flying past that setting.
      can you pls confirm if according to logs it still thinks it is on USB power or if it is something else?
      https://www.dropbox.com/s/wbtlamaouj3aval/7.BIN?dl=0
      also this first log did exhibit a different glitch showing for first primary GPS unit a steady HDOP value of 0 for an entire flight. see picture and log also reflects same thing. not sure why second time it worked, I just disconnected power and reconnected it back hoping that it will make battery failsafe to work, but, no use. it is not working.
      Still, on a second flight it did set to something reasonable. I also noted behavior flying next to my house has improved a lot, it is not lurking around as much as before.
      MP software still gives same error for 'Time' if you try to run auto analysis.
      Dropbox - Error
      Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    • what for an issue? I fly the AUAV-X2 with RC5, RC7 and now with RC8 an no Problems. This Board works fine.
      • http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId...
        DG,
        It looks like bad interference on the compass.  Compass-mot is set-up but it doesn't seem sufficient to counter act the effect.  Probably the best thing is to try and move the compass away from power wires, etc.
        I'd qualify this as a "fly-away" and the EKF check would have stepped in and switched the vehicle to pilot controlled land except there is a known hardware issue on the AUAV-X2 boards in which it always believes the usb cable is connected and so the EKF check (and battery failsafe) are disabled.  We have a software work-around coming in -rc8.
  • After updating to rc8 I can't enable throttle failsafe without pre-arm check fail regardless of parameter setting on both my quad and hex.
    RB
    • Solved....... Appears to be a much larger threshold for Failsafe throttle min.  I decreased the value until it passed pre-arm check and everyone is happy.  I just came in from several test flights with all three of my birds and can't find any issues with rc8, but then rc7 was solid for me as well.
      Thanks to the Developers and everyone that helped, this is a very stable platform
      Cheers,
      RB
    Copter-3.3-rc8 will is on it's way out to Mission Planner's beta firmwares area (it should appear in about 1 hour).
    The full list of changes are in the ReleaseNotes and listed below.  The list is perhaps longer than we'd like for such a late release candidate but hopefully this will be very close to the final AC3.3 release.  The critical fixes are (1a) EKF’s vibration resistance, (3a, b) TradHeli fixes and (5a) bug fix for THR_MIN.  The rest are mostly small fixes that could be done in parallel with the critical ones.
    Changes from 3.3-rc7
        a) de-weight accelerometers that are clipping to improve resistance to high vibration
        b) fix EKF to use primary compass instead of first compass (normally the same)
    2) UBlox "HDOP" corrected to actually be hdop (was pdop) which leads to 40% lower value reported
    3) TradHeli:
        a) Motors library split into "Multicopter" and "TradHeli" so TradHeli does not see multicopter parameters
        b) Heading target reset during landing to reduce vehicle fighting to rotate while on the ground
    4) Minor enhancements:
        a) SToRM32 gimbal can be connected to any serial port
        b) log when baro, compass become unhealthy
        c) ESC_CALIBRATION parameter can be set to "9" to disable esc calibration startup check
        d) Circle rate adjustment with ch6 takes effect immediately
        e) log home and origin
        f) pre-arm check of battery voltage and fence
        g) RTL_CLIMB_MIN parameter forces vehicle to climb at least this many cm when RTL is engaged (default is zero)
    5) Bug fixes:
        a) fix THR_MIN being incorrectly scaled as pwm value during low-throttle check
        b) fence distance calculated from home (was incorrectly calculated from ekf-origin)
        c) When flying with joystick and joystick is disconnected, control returns immediately to regular TX
        d) dataflash's ATT yaw fixed to report heading as 0 ~ 360
        e) fix to mission's first command being run multiple times during mission if it was a do-command
        f) ekf-check is enabled only after ekf-origin is set (stops red-yellow flashing led when flying without GPS lock)
        g) fix initialisation of mount's mode
        h) start-up logging so parameters only logged once, mission always written
    6) Linux:
        a) bebop support
    Thanks as always for this group's testing efforts.  Almost there I hope and then we can open it up to the wider community.
    • Randy, same question as DG, were you guys able to fix the x2 issue with USB connection status? Thx!
    • Hi Randy.
      Great work!
      If I understand correctly this:
      is fix for my case?
