Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Nathaniel,
Thanks for testing and for figuring out the Fence issue. I'm pretty sure you're right.
The low HDOP value is because of the "Note #1" mentioned in the main part of the discussion above. It's a bug fix to the value pulled from the Ublox (previously it was actually "PDOP").
The "Need 3D Fix" message is clearly a message we need to clarify because someone asked this same question about 2 days ago. The EKF has a bunch of other tests it does including checking the GPS velocity but we always display the same failure message regardless of which of those checks have failed. In short, what you're seeing is the EKF isn't yet happy with the info coming out of the GPS.
Hi Randy,
Have we got any closer to what to do with this issue? I understand that the message is ambiguous in APM:Copter V3.3-rc10 but I have not been able to find a way out of it. Do you have any suggestions as to how to track down why EKF is unhappy?
I have tried disabling PreArm checks entirely and thepre warning message persists. The LED shows flashing blue when any GPS-reliant mode is selected prior to attempting to Arm. In Stabilize mode (as expected) the status LED is green and arming is possible.
I have on occasion seen the Pixhawk status light go green in GPS (Fence enabled) mode if I wait long enough. Yet the HUD says 3D fix and Sats are >= 6.
Danny,
Sorry but did you post dataflash logs anywhere? Ideally with the logging-while-disarmed bit turned on. It's likely that the EKF is unhappy with the velocities coming from the GPS but we will need logs to be sure. The "Bad AHRS" message sounds like something else is going wrong (like an IMU).
Randy,
Thanks for the explanation. I understood about Note #1, I wasn't concerned with the number per say, it was really the fact that I got it almost immediately upon powering up while I was indoors! That seems very unlikely.
Any clarification on the units that the sonar values are when reported on the Mission Planner status tab? Or the pitch oscillation I'm seeing when I reach the value of WPNAV_LOIT_SPEED?
Thanks,
Nathaniel ~KD2DEY
Yeah I autotuned roll and pitch axis with rc8 yesterday with aggressiveness set to 0.5. Roll axis is OK but pitch axis took forever to autotune and now I get slow oscillation on the pitch axis when it recovers from significant pitch movements. I'm going to re-autotune today with 0.7aggr and see what happens.
Hi Fnoop,
0.5 is way too high, that will be limited internally to 0.2. I hope you meant 0.05 but it is worth checking you didn't make a mistake.
My suggested range is 0.05 to 0.1.
Has anyone else had trouble geotagging gopro pics via mission planner with 3.3rc8? Works well with 3.2 for me. When I tried with 3.3, using time offset, est offset always shows -1, then pre processing finds no matches. 3.3rc8 log below.
2015-07-30 16-45-21.bin
Hi Chris
A few people noticed this problem. You can find another simple geotagging method here:
http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId...
Randy, maybe it will appeal to you to compile something like 3.2.2 with most of the 3.3's non flight control related features like different gimbal serial support, retracts and some other kinks? I think it is beneficial for both the AC project and us is users as we'll get some useful features on a hell of a stable platform, while you guys will get a chance to iron out any bugs in the said non flight control related features at the same time you will get some more time to work on the EKF and make 3.3 something really great instead.
Hello,
Is this negative baro readings are ok in flight?
