Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • Can you explain please? As I can see via IMU/IMU2 vibration is acceptable.
                • T3
                  The IMU data is based on filtered accelerometer data, whereas the vibes are calculated on the raw IMU data.
                  Also your Acc data are (randomly; at least not related to pitch roll and yaw) increasing heavily. And since there is clipping you definitely have too high vibrations.
                  The best way is to look at all these data (IMU, Vibes and clipping) and to use the worst for interpretation.
                • T3
                  Evgeny,
                  you should look at the Vibes messages (see: http://copter.ardupilot.com/wiki/common-measuring-vibration/ for more details).
                  As Rob mentioned the vibes are "extremely, extremely high" on your copter - they go up to 120. Normally it should be below 30. Below 50 should be ok. Depending on the damping system, the balancing of the props, and the frame setup it is possible to get the values below 10 even for larger copters (for in Loiter the vibes on one of my copters are < 5).
                  I suggest to change the damping system and to carefully balance the props/motors.
                  3702927619?profile=original
                  • But IMU AccX, Y, Z level acceptable (IMHO). So I don't understood why IMU vibes good but VIBE section are bad.
  • Have tested from rc1 still have the very same experience that position hold is behaving strangely (1) unreasonable rapid roll movements (no wind) after switching from Loiter (2) very bad breaking performance even with max settings (angle/speed of change).
    3702059864?profile=original
    [cannot upload logs due to size]
      Robert,
      No much has changed in PosHold vs AC3.2.1 but it's certainly possible that it's been broken somehow.  Have you tested AC3.2.1's PosHold with the same parameters to see that it performs better?  I'd just like to confirm that this is an AC3.3 issue instead of a general PosHold performance issue.
      • Randy - you might be right, I did not use/test position hold intensively before 3.3 so I am not sure. Due to the nature of problems (copter movements) I assumed it is EKF related but it is assumption only.
  • This reply was deleted.
    • Probably not helpful, but my radio telemetry works fine on rc8.
      It's working on telem1 as well as telem2.
      Do you have something else connected in parallel with the telemetry radio with an Y cable?
    • I´ve the teensy working with -rc8
  • Hello Folks,
    since -rc8 was released I´m using it. I´m flying every Day min. 1h. No faults every thing worked very good.
    Only on thing does not response is the "DO_CHANGE_SPEED" command. Just nothing happens! But I´ve to say that I´m using ch6 to change the WP_Speed. My thought is the the DO_CHANGE_SPEED command overrides the WP_Speed and if a new WP_SPEED comes from ch6 it overrides the previus command.
    I would appreciate a "condition_change_speed" AND a "condition_change_VS" (VS=vertical_speed).
