Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • Can you explain please? As I can see via IMU/IMU2 vibration is acceptable.
                • T3
                  The IMU data is based on filtered accelerometer data, whereas the vibes are calculated on the raw IMU data.
                  Also your Acc data are (randomly; at least not related to pitch roll and yaw) increasing heavily. And since there is clipping you definitely have too high vibrations.
                  The best way is to look at all these data (IMU, Vibes and clipping) and to use the worst for interpretation.
                • T3
                  Evgeny,
                  you should look at the Vibes messages (see: http://copter.ardupilot.com/wiki/common-measuring-vibration/ for more details).
                  As Rob mentioned the vibes are "extremely, extremely high" on your copter - they go up to 120. Normally it should be below 30. Below 50 should be ok. Depending on the damping system, the balancing of the props, and the frame setup it is possible to get the values below 10 even for larger copters (for in Loiter the vibes on one of my copters are < 5).
                  I suggest to change the damping system and to carefully balance the props/motors.
                  3702927619?profile=original
                  • But IMU AccX, Y, Z level acceptable (IMHO). So I don't understood why IMU vibes good but VIBE section are bad.
  • Have tested from rc1 still have the very same experience that position hold is behaving strangely (1) unreasonable rapid roll movements (no wind) after switching from Loiter (2) very bad breaking performance even with max settings (angle/speed of change).
    3702059864?profile=original
    [cannot upload logs due to size]
      Robert,
      No much has changed in PosHold vs AC3.2.1 but it's certainly possible that it's been broken somehow.  Have you tested AC3.2.1's PosHold with the same parameters to see that it performs better?  I'd just like to confirm that this is an AC3.3 issue instead of a general PosHold performance issue.
      • Randy - you might be right, I did not use/test position hold intensively before 3.3 so I am not sure. Due to the nature of problems (copter movements) I assumed it is EKF related but it is assumption only.
  • Hi all, quick question if I may.
    Since upgrading to 3.3rc8 I'm having problems connecting via the radio telemetry port. I no longer get the flashing red LED on the air side half of the pair. I thought the receiver had failed and purchased another one. But this is the same.
    I can roll the firmware back to v3.2.1 and everything works fine but as soon as I revert back to 3.3rc8 it refuses to work.
    I read this thread daily and don't recall any notes about this so I thought I'd ask.
    Any ideas?
    regards
    Mark
    • Mark,
      I'm going to assume here that you are using telem1 for your radio.
      If you connect your telemetry via less than 6 wires, IE, your radio doesn't have or doesn't connect RTS/CTS and if you have BRD_SER1_RTSCTS configured for automatic flow control (2, the default), then you have encountered the bug I reported here: https://github.com/diydrones/ardupilot/issues/2532
      This bug was present in the code for older releases, but seemed not to manifest there.
      You can work around the bug by setting BRD_SER1_RTSCTS to 0, no flow control.  Please let us know if this is your problem.
      I submitted a pull request 3 weeks ago which fixes the bug and also vastly reduces the time required to detect the lack of flow control, but so far the developers do not seem to have had time to review and merge the fix.
      --Brad
      • Thanks for the replies gentlemen,
        The problem was fixed by Brad's suggestion. Working on 3.2.1 but not on the latest really confused me.
        I really appreciate your help.
        cheers
        Mark
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
