Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I think only more or less supported mini board is AUAV. on that one you got you will probably be on your own.
        http://arsovtech.com/?page_id=1502
        AUAV has its Chinese clones getting sold on ebay as well. Not sure if it is worth doing, better get it from the maker, even if takes time. Vertical pins model is more compact, it is one on the Tarot image above. You can see even in the case (from shapeways) it fits in between 45mm posts - case has 45mm mounts, where those posts go into, screwed in and superglued. An awesome board for its compactness, but, has some quirks too.
      • 3702711843?profile=original3702711906?profile=originalBy same reason I stopped mounting GPS on the mast and it sits firm on 4 posts on the drone.
        Mast is not helping at all and causes EKF issues when your compass wobbles.
        Best way is to do proper EMI blockade is to sit GPS on top of a carbon plate that has a layer of copper foil glued to it. copper foil like same that is used for electric guitars. It works better for me than any mast mount.
        Just make sure not to use any metal bolts/posts on the GPS unit you will use as a compass.
  • Flying with 3.3r8 loiter was very mushy and would drift a good distance when transitioning from moving to stop.
    When I checked the Loiter PID's in MP the Loiter PID's are greyed out and not adjustable.
    [URL=http://s1239.photobucket.com/user/86burbguy/media/Mobile%20Uploads/DBBF1154-7A31-42CE-998D-C13C8C6B12DD.png.html][IMG]http://i1239.photobucket.com/albums/ff502/86burbguy/Mobile%20Upload...[/IMG][/URL]
  • A little off topic as this has nothing to do with airworthiness.  My mapping rigs running 3.3rc8 are doing funny things in the processing phase.  Can't sync the geolocation info with the images using mission planner.  All I get is "aboring"  as seen in the image I attached.  I can use Pix4d to syc the data up, but Pix4d thinks all the images are portrait mode instead of landscape.  First thing I check the next flights was the camera facing forward was checked in survey grid, but Pix4d still thinks it's portrait orientation.
    https://storage.ning.com/topology/rest/1.0/file/get/3702056218?profile=original
      Hello everyone,
      @Shaun, this mistake is due to the inclusion of the variable "Timeus" to CAM messages and restructuring of the message CAM data. Note that the variable "Timeus" has been included in all messages, so the messages ATT and GPS are also affected. To fix this, simply adjust properly "offtsets" in the setup screen Geotag Mission Planner tool.
      Your configuration is incorrect, with new releases, for ArduCopter, Mission Planner must be set like this:
      3702585420?profile=original
      I hope I've helped.
      Regards from Spain,
      Dario
    • I just performed a mapping flight and I'm having this exact same issue trying to geo-ref my images with 3.3-rc7.
      Using AMSL Altitude True
      Reading log for GPS Messages in order to get AMSL Altitude
      Log file problem. Aborting....
      I'm guessing it's because of the size of the log file with all the fast IMU logging enabled (80mb). Does anyone have a workaround? It's quite important to get these images geotagged!
      Edit; I can see the CAM messages are in the log if I filter them out. Is there any way to export these into their own log or otherwise work with them?
        Good to have these reports.
        It's possible that it's because of the changes to the size of the time field.  I've created an item here for the Mission Planner to investigate/fix this.
        • Thanks Randy.  I've got Pix4d looking into making sure their software will works with 3.3 logs as well.
          • Pix4d says the kappa angle is 90 degrees off and that's causing the orientating problem with their software geotagging.  CAM, 595372339, 339994200, 1854, 49.8042384, -119.4715983, 578.83, 69.99, 2.10, -9.35, 266.46.  In my quality reports I get and RMS error on kappa at 89 degrees.  Sure it won't be too difficult to fix : )
        • Thanks, let me know if you need any logs, but I would assume this is an easy one to recreate.
          Is there a potential workaround in the mean time?
