Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm not a reference to ensure that because this copter is the first time that fly well with so strong wind; it wasn't so quiet for a nice video, It's need a fine tunning yet but Isn't a day to take nice quiet videos (and no my interested too, I like photos), but the copter looks strong flying against the wind. I'm very happy :D
I'm going to give a try today too if weather permits and report results.
Randy, I share the log of my failed take off here, http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId... , we wrote a lot of pages them and I affraid you can't notice or you can't open; if you don't have enougth time to see, or a human err only, no problem, isn't so important, I know that I have to pay more attention when I take off.
Has anyone given Copter-3.3.1-rc1 a flight test? I'm thinking of releasing it soon but I just want to be sure some other people besides me have tried it. The bug fix is incredibly minor, it's more the compiler upgrade that I'd like to have a bit more confidence in.
Everything is fine.
Good to go!
Ok, below is the real and not fantasy VIBE results after making some adjustments in the FC mounting. I tried AT with the earlier VIBE numbers, and that didn't work out too well. It almost flipped and did other odd things.
Tonight I flew with the below vibration results, but too windy to AT. One noticeable event was it occasionally would Yaw as if it were trying to adjust the heading. It did that with the high vibrations, so I chalked it up to that. What usually causes a quad to Yaw without sending a Yaw command?
Yes, like Cala says interference on the compass from the motors is one possibility. The other possibility is a large-ish motor imbalance.
If it's compass interference then you could see it in two ways:
The motor imbalance is quite easy to see from the dataflash logs. Just take a log from a vehicle doing a regular hover and plot the first 4 channels of RCOU message (assuming it's a quad). If the distance from the highest to the lowest motor is over 200 or 250 then the motor imbalance could be the cause. Perhaps one of the motors is tilted.If you post a dataflash log I can peek at it if you like.
SpeedyHulk,
Here it is for the log, it shows an imbalance of about 100pwm which is fine. I encourage you to try it yourself though, it's really very easy to produce these types of views.
Yes, I like the EKF viewer feature. Today it was quite windy and I was just glad to land before it ended up in the woods or a tree/barn......landed and totally forgot to look at the EKF stuff.
I didn't post the VIBE from when I did the AT yesterday, but they were ridiculously high with lots of clipping; don't know why it got worse from the other day, but the AT was aborted after the acrobatics show. That prompted me to redo the FC mounting.
This is from the AT attempt.
2015-10-23 18-09-55.bin
88
89
90
91
92
of 449 Next
