Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Lukasz,
Based on the feedback so far and looking at the range of measurement results I have on hand, I am thinking that 0.65 should be very close for most copters.
Thanks for the feedback and data point!!
dronebohne,
I think your mission planner may be out of date or perhaps it's just not the beta version so it's showing the parameter descriptions for Copter-3.2.1 instead of 3.3.
"3" is FrSky DPort
"4" is FrSky SPort
Here's the code where we set the values the mission planner should display.
For my iris+, I use 3.
I had a similar issue with S-Port telemetry. I set it to 3 and it didn't work but setting it to 4 works great.
I am considering testing 3.3 from 3.2. It’s been flown many many times on 3.2 and it flies decent. Is there anything in particular the devs would like to see or need at this point? Should I do a flight twice the exact same way one in 3.2 and one in 3.3 and post logs or is there something even more specific? The only think I’d like to see improved is flying in wind. Perhaps I just don’t have it tuned perfect but I’ve done the best I can with it but it does seem to wobble a bit in high wind and or the normal bouncing on fast deceleration.
Richard,
Sure, please give it a try. It's quite stable now it seems and we're just working through real edge cases mostly before the final release.
Really what I'd most like to see is -rc9 dataflash logs from high vibration copters especially those that exhibited attitude control problems with -rc7 and -rc8.
I wait for your results with windy, finally I'm waiting for a Pix to experiment with wind and ex-old cuad :D
@Pomaroli: thumbs up!
nice piloting skills there. Here is a short clip of my quad cruising during the rc7 release.
Wow!! I feel dizzy, impressive, the camera is cmos?
192
193
194
195
196
of 449 Next
