Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Wes,
      Yes, I think Leonard wants to add the Z-axis autotune to AC3.4.  We're also going to improve the user interface for autotune so the GCS can tell the user what's going on.
      • Wow, Arducopter is getting better every day!
    If I recall correctly WPNAV_UP and _DN used to control the climb rate in althold, this no longer seems to be the case in v3.3, what controls it now?
    • Hi Graham,
      I think that the climb rate in AltHold (or any other mode when the Pilot controls atlitude such as PosHOLD, Loiter etc.) is controlled by:
      • PILOT_VELZ_MAX controls maximum vertical velocity in cm/s and
      • PILOT_ACCEL_Z controls vertical acceleration in c/s/s
      • ALTITUDE_HOLD_P  will determine how aggressively ALTHOLD modes will try to maintain the current Altitude.
      The WPNAV_UP/_DN params are the climb rates that the controller will attempt to achieve when chaning altitude on its own.  (i.e. You are not manually applying throttle to climb or descend. For Example, during a mission or when changing ALT in GUIDED or during RTL)
      CHeck the wiki for detailed info: Altitude Hold Mode
  • Hi Greg,
    Sorry about your crash....
    I had problems with Qbrain in other platforms (32 bit boards.)
    I spent one month to understand the problem….really hard….…. After more than 20 crashes, I simulated the problem on the ground …. With physical support one axis platform
    And the problem occurs without “loops” too…. With fast commands
    So.... maybe is a similar problem.... “frequency”… I don’t know…
    and with old APMs boards no problems....
    Video with Q Brain (look the video description) 1 year ago….
    https://www.youtube.com/watch?feature=player_embedded&v=yKyrdje...
    Video afters change Q Brain
    https://www.youtube.com/watch?v=sRT8Hpk0kqU&feature=player_embe...
  • Looking at the Alt hold performance on a breezy day for RC10 it looks like the Alt graph line is following the DAlt better than the BarAlt. does this mean the accelerameters are out performing the Barometer under these conditions or is it an avalible trust issue making Alt look better than Baro Alt?
    What could be done to improve the alt hold in this case?
    3702084933?profile=original
    Just for reference I will post the IMU, Vibe and RCO graphs.
    3702084951?profile=original
    3702084673?profile=original3702084690?profile=original
      Hi Wes,
      DAlt is what the controllers are being told to do. Alt is the estimated altitude the controller is using and trying to make equal to DAlt. BarAlt is the raw output from the Baro before it is combined with the accelerometers.
      I believe we can do better in this area than we are currently.
    Trent,
    I'm really not aware of any changes that would cause that kind of behaviour.  As far as I know when the throttle stick is moved just above the top of the deadzone (for example) it will command a very small climb rate, not 20%  We can look into this but the log would be good to see first when you get a chance to upload.
  • Went out to test rc10 this morning on my PH deadcat running Tiger MT4006s 10 inch props on 4s.  Took right off in althold and stabilize so I decided to run the autotune set at .07 -AGGR.
    It took about 13 minutes to tune the three axis.  The motions were much less pronounced than autotuning in 3.2; pitch and roll seemed to be about 15 degrees as apposed to the 30 degree plus when ATing in 3.2.  Decided to land and disarm due to low battery warning.
    Swapped batteries, installed Gopro and armed.  On throttle up immediately one motor failed to spool up to full speed, I dropped throttle, but it was too late.  The Vbrain 25a 4-in-1 esc burst into flame.  Fire went out in about 5 seconds with no other damage to the CF framed quad.
    Wasn't sure how to set logging but it appears that MP 1.3.31 doesn't like the files.  It will not auto analysis the logs.  Message" Could not add reference to assembly mtrand.dll" followed by "Bad input file".
    Am I just snake bit again or is there something in autotuning rc-10 that could have stressed one motor in 15 minutes?
    Logs included:
      Hi Greg,
      Sorry to hear about your burnt ESC. I don't believe there is anything that has changed that could cause this to happen.
