Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Leonard! Got it.
I've done that and now it looks awesome. Many thanks
I'm getting Bad AHRS when powering up my Pixhawk. This only happens when I first power the unit up so I think something is going bad. And yes I did short out the power leads to the copter and this makes no difference.
The problem is I don't know what is going bad since it only happens for a short time before correcting itself which causes the error. The unit doesn't correct itself except by unplugging it and plugging it back in. Is there a way to determine what Bad AHRS is?
I'm getting that on 3 different hawks right now :( 2 lites and 1 full.
I would agree with you except I have two Pixhawk units one does it everytime the other never does it.
I think those are ****hawks and not a 3DR Pixhawk, correct? It seems that *hawk manufacturers do not know how to properly power down LS303D or they are using a cloned one with slightly diffferent specs with the original pixhawk schematics. I suggest when you short the power input, short it for full 4-5 seconds as the goal is to discharge capacitors behind all the voltage regulators and unlike ESC caps those do not fully discharge with a momentary short.
Unplug, short and replug. Some times it takes a couple tries to get the error to clear.
I have wondered if I was a timing issue, to many checks running at one time or the system coming on line before the checks are complete.
I have thought this issue could be embarrassing if I was doing a demo for client or when getting air born was very time sensitive, say in a life guard senerio attempting to fly a floatation device to drowning victim.
Fast start up has not been a strong point on any GPS utilizing FC brands I have worked with.
I have hope that eventually it will get sorted out.
@ Michael B, I only ran into this when I first started running EKF. It was explained that there is a lag with EKF starts running. Therefore the momentary "Bad AHRS" which clears itself. If it doesn't clear that is another matter (I've never experienced that).
This should not to be confused with the "Bad Gyro Health" problem requiring the shoring of the pins protocol.
TO ALL DUAL GPS USERS!!!
Hi, for those who followed this thread it was discussed multiple times about vehicle been unstable if we have 2 GPS onboard.
I followed Randy`s suggestion (sorry if it was somebody else`s, but it is not an important part :) ) and I adjusted parameter for both GPS units to use only GPS system satellites, namely GPS_GNSS_MODE parameter was altered from 0 into 1.
It has resulted with significantly shorter list of visible satellites, I have 2 M8N units on board, so it has dropped from 19-21 sats down to 11-12 on second GPS and 13-16 on bigger GPS unit and HDOP is stabilized around 0.85. It picks them up same quick as before, that did not change.
Early morning field test had both GPS units on 11 sats with no position jumping at all, test on front lawn shows 9 sats firm on smaller GPS and mostly 15 on bigger one getting sometimes to 16 or dropping to 14. Still, a stability of pos hold was close to perfect compared to what it was before.
So for now it is how I will keep it. Test on my front lawn also proved it to be working way better - this non-stop wandering around has stopped, vehicle seems to sit in one place in pos hold like it is supposed to be.
The parameter description issue is a problem with MP so I've raised an issue for MichaelO here.
Until that's fixed, the correct GPS_GNSS_MODE parameter descriptions are here. The @Values show numbers that can be put directly added and put into the parameter. If you're ok at bit math then the @Bitmask description shows the meaning of each bit in the number. Eventually MP will be fixed and we can all just use checkboxes again.
So I recommended "3" because this enables the "GPS" satellites (i.e. the US Govt satellites) and "SBAS". All other systems like the EU Galileo, the Russian GLONASS, etc are disabled. This is why there are fewer satellites seen but my understanding is that the GPS constellation is the most reliable and sometimes using glonass can actually reduce the accuracy of the solution.
Enabling "SBAS" can also be bad though depending upon where you are in the world. in the US and Japan it's definitely better to have it, in Australia though it can make it worse.
Hope this helps.
I´m flying pretty often @ my shaded backyard as well ,-)
