Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • check mark it off.. then when your copter is lost... yell out loud "help ive lost my copter and i cant find it"
      then press your medical alert button and youll be all good lol sorry just some levity
  • I had compass error with rc10, I disconnect ext compass and try many times to recalibrate and compass variance still there, I only change to Rc11, no new compass cal and int compass works well now.Thank's.
  • 3.3rc11  , on a 3dr X8  I did Roll and Pitch individually and they completed ok. When I try to tune YAW it takes over 6mins and does not complete. I run out of battery and have to land. I land by switching to stabilize while leaving CH7 on in autotune and then disarm. When I check the params it doesn't seem to be updating any new PID's for YAW. I've tried it twice with the same results. I was hoping I could run it several times and get it to complete. Am I doing something wrong?
    Doug
      Hi Doug,
      If you give me a yaw tune log I will be able to give you the tune it ended on. Each time you start autotune it begins from the tune you are flying.
      Leonard
      • Hi Leonard,
        Leonard, Thanks for the reply
        I checked the tune log before I saw your reply and, although I don't understand all the info, I could see that the starting numbers needed to be much higher. I increased the  Stab_P, Rate_P, Rate_I significantly. And tried it again and it completed.
         It was starting from     Stab_P 2.5, Rate_P .16,   Rate_I .02, Rate_D .005
        I increased it to           Stab_P 3.0, Rate_P .250, Rate_I .10, Rate_D .005
        It then completed with  Stab_P 7.2, Rate_P 1.07, Rate_I .107, Rate_D .000
        Doug
  • Tonight my test quad flew a 3.7 mile mission perfectly on 3.3 rc11, and landed on a dime. This copter uses a RTFQ 55mm M8N with standard GPS scipts, no second GPS, and AUAV-X2 FC. No warnings or surprises.
    I used Tower with the EKF monitor; excellent feature.
    The only problem now is the logs won't download from the USB.
  • This reply was deleted.
      esamolocik,
      Thanks for testing and sorry for taking a while to review your logs.
      I can't help with the autotune but at the end of the log the vehicle was in Stabilize mode.  You probably know but just in case, in stabilize mode the pilot has full control of the throttle.  Essentially the pilot controls the vertical acceleration.
      The CTUN's ThrIn and ThrOut look pretty consistent with the Altitude ("Alt") and climb rate ("CRt").
      3702595465?profile=original
    • I think you pushed the battery too hard. You can see the requested throttle shoot up at the end, the current spike and the voltage fall off a cliff all at the same time. You aren't logging RCOUT so its hard to see what the motors are doing.
      If this is 4S you should set the battery failsafe higher - say at 14v or more.
      My $0.02
    I had a flight about a month ago on AC3.3 rc8 in which I had an EKF triggered failsafe as well as a later NO-RC Receiver failsafe. Up until this point (and immediately after changing modes) everything has been fine, and seemed fine at the time. I'm hoping someone can review the log and give me an idea what caused the EKF failsafe and how to prevent it in the future. I think it is compass related and not sure if there is an indication I need to re-calibrate the compass, or if it's something else entirely.
    As to the RC Receiver signal I'm stumped. The RSSI was about 97 right before the failsafe then dropped to 0 for about 1/3 sec. the failsafe was triggered then it was back to 97.
    The short clip below shows the various screenshots of the tlog replay with VIBE and EKF scopes open (love these by the way).
    Attached are copies of the above video clip, and a copy of the tlog.
    Here is a link to the BIN file for this flight on my Google Drive.
    I haven't had any time to fly since this flight and want to upgrade to AC3.3 rc11 before my next flight, but I want to understand what's going on here first.
    Nathaniel ~KD2DEY
    2015-08-16 14-30-03.tlog
    2015-08-06.wmv
