Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • thanks but that's not the situation.
  • Congrats for the new Release 3.3 !!!
    Is it possible to bring under two small changes i haven't seen so far ?
    1. Throttle mid minimum value seems to remain stock on 300, could it be set to 200 ?
    2. Could the Battery FS Alarm be reset by disarming the vehicle ? As it is now the Battery need to be disconnected.
    • Hi. I have asked for the same thing too. It is useful for those of us who use a double power system to take off as soon as the battery is replaced.
      I think it will be done for 3.4
    • AH!! that's the reason because batt Beep under time, thank's
  • sure - i totally get it. if i had a specific mode already dialed in i would be hesitant to fuss around with a new mode. but I believe you can do everything needed on adjustments with poshold as well.
    Copter-3.3 is out as the default version!  Thanks again to all the beta testers on this thread!
    • Installed and flew it today, all seems to be well except of gps switching between units. I ended up disabling that parameter for auto switch and then it was all fine, very stable.
      Other thing - for my armattan i set all filters to 40hz from default 20hz and it works way better this way.
      Looks like a great release.
      I think for dual gps systems a better logic would be to put in a check if primary gps unit goes completely kaput - like time update stream stops or something like that and only in this case to switch into a backup unit. This 'on the fly' switch mode should probably be removed as in practical reality it causes more trouble than good.
      • Hi what gps are you using I had this problem when I had a 3dr 6h and a Neo7 which would cause it to move say up to 2ms when it switched gps I cured this by changing to two 3dr gps so now it's hardly noticeable the moment between the two gps hope this helps
        Stuart
    • Congratulations. Thanks all devs for your efforts.
      I am already on 3.3rc12- Do I need to update to GA code? or is it still the same code and I don't need to update.
      Thanks.
    • Hello Randy,
      is the version 3.3 still without mkblctrl? If so will the mkblctrl be discontinued?
      As I am using these ESCs I cannot upgrade.
      Regards
      Derek
DIY Robocars via Twitter
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Monday
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Monday
Monday
Saturday
Saturday
Saturday
Friday
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
Jul 4
Jul 4
