Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Andy,
What youtube clip? I went back through the past 10 pages or so and I didn't see a link to a youtube clip.
Nathaniel ~KD2DEY
Sorry, slight misinformation on my part :) Follow this link and the clip it links to:
http://diydrones.com/forum/topics/demo-of-magnetic-effect-on-compass
Took a few seconds ....... about 20% right of the left margin and about 25% down?
I can imagine you going nuts looking at hours of that sugar cane!
One went on a full sized sailplane retrieve where the guy had landed in a sunflower crop field. The sunflowers were ripe so the field so looked black like a nice inviting ploughed field from above. It was only when he was committed that the pilot saw it was a tall crop ( also about 2.5 to 3m tall )
Plonked it in and sank to ground level. We drove around the perimeter of that particular field ( several hundred acres ) more than once. Aircraft was only 50m in from a boundary but totally invisible. :) We found the pilot at a farmhouse eventually. He'd tied a jacket to the fence near the aircraft to mark the area and even then you could walk 15m away and not see a 15m wingspan bright white full sized aircraft!
We took several buckets of dry sunflower seeds out of the fuselage when we got back to the airfield!
This was all 40 years ago, if we'd had a UAV it would have been a lot quicker to find it! :)
Nate,
Looks like a motor imbalance. In particular motor #3 (front left) is looking weak.
not sure I understand this parameter setting for EKF_FALLBACK, how can EKF fallback to itself? or am I misunderstanding (am sure I am!)
whats the basis for using either option? would love to hear from one of the devs
IvanR,
This parameter is ignored in Copter but is used in Plane. We could probably hide it but in any case, in Plane they allow the user to choose whether to use DCM or EKF but for Copter that's never a good choice because DCM can't do the position accuracy we need for RTL, Loiter, etc. There is one exception in that Copter will fall back to DCM if the EKF has NaNs appear within it. This should never happen because we should have the necessary checks in the code to stop it from happening.. but the fall back is there just in case.
I made a mistake during the release process yesterday and TradHeli has accidentally been upgrade to Copter-3.3. The testing for TradHeli isn't complete so we will revert it to Copter-3.2.1 asap. Any TradHeli users out there reading this should not upgrade to Copter-3.3.
Multicopter users should not be alarmed, this is a TradHeli specific warning.
Hi Randy,
THANK YOU for all the hard work !
I tried '3.3heli' yesterday, it didn't show any problems during 4 flights using Acro, Stabilize, AltHold and PosHold. I would change some defaults, like RATE_PIT_P=RATE_RLL_P * 3, RATE_PIT_D=RATE_RLL_D * 3, RATE_YAW_I = RATE_PIT_I and most important ACCEL_Z_P=0.5 never worked for me. Usually I use ACCEL_Z_P=0.3 to 0.4 therefore a default of ACCEL_Z_P=0.2 should be o.k.
Could you please add RATE_YAW_I and H_COLYAW to the TUNE options for channel 6. It would be nice to have reasonable heli limits in MP in the future as well.Can you please tell me what version the '3.3 stable' really is ?
Ultrafuge,
By the way, a good way to ensure requests aren't lost is to directly add them into our issues list. If it's a tradheli issue then it's probably good to add "TradHeli:" to the beginning of the subject line so it's obvious. Normally someone from the dev team will go through and tag, maybe clarify it a bit and for those items that we promise to put into the next release, we normally set the milestone (like these for Copter-3.4). Sometimes not all of that happens but that's the idea.
Hi Randy,
I hope it is o.k. like this:
TradHeli: New defaults for 3.3 #2974
104
105
106
107
108
of 449 Next
