Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Loaded 3.3 today, previous 3.2.1 flies fine in PosHold but with 3.3 I got error (Flightmode err 16) and PosHold is not working
Loaded 3.2.1 back and it is rock solid in Poshold.
I did not change anything between the 2 versions
Log from 3.3 attached 2015-04-13 19-18-15.log
Log from 3.2.1 attached 2015-04-13 18-38-21.log
Did this (Note #1: because of the accelerometer range change (see 6b below) this upgrade will require the vehicle's accelerometer calibration to be done again.)
Logs zipped
logs.zip
APM Planner won't calibrate accelerometers after 3.3
I screwed up and started a discussion instead of a reply so copied to this discussion
I am pretty sure this was caused by the 3.3 upgrade. I have successfully calibrated the accelerometers many time recently and when I tried after 3.3 it times out and will not calibrate. I hooked up my trusty Iris after several attempts on my 550 and the Iris responded as normal. I then hooked up a spare pixhawk and uploaded 3.3, attempted a calibration with no results. Neither unit will calibrate now even if I revert back to 3.2.1. I took the 550 to School today and successfully calibrated 3.3 with a PC running Mission Planner. I came home this afternoon and uploaded 3.3 to my Iris and it now has joined the other two in the calibration fail pile. I am now out of tricks and could use some help.
RB
I tested 3.3 today with a early model lidar-lite attached using the PWM interface, following the wiki instructions.
It appears to work hand-held (sonar alt makes sense while disarmed.) However, I had rapid, short climbs when switching into alt hold or pos hold.
My quad is a bit heavy for it's size, 400 class, 8" props, 1.8kg but flies fine on 3.2.1. Winds were light and variable.
Here's the flight with Lidar-light active. Here's one without.
Also, I'll add to the report that Pos hold is not showing up as a valid mode, but only with the lidar active.
Are there any plans in the future for Altitude Verification/Input using LidarLITE?
I noticed an immediate improvement on my newly built quad. It takes off much more nicely and descent is smoother. No Auto Tune done yet, but just did one yesterday with 3.2.1. Based on comments I think I'll wait.
That's my 2 minute observation report :)
Is there any more information on what changed to reduce the CPU load so drastically?
I hesitate to respond because I'm pretty vague on this one, but just to try to answer... It was something like, the processor was spending a lot of time doing stack overflow checking or something, and we don't need to do that at all because we never use dynamic memory allocation. Basically, it was spending a lot of time doing something that we didn't need it to be doing. It wasn't a change in the actual main code.
Did a first test with 3.3-rc1 today. The F450 flew quite nice with the default settings, did an Autotune and it is a little bit more rapid after the autotuning but is seems as it doesn't stabilize as quickly as before the autotune
PID settings before and after tuning are in the end of the video.
http://www.maciej.se/F450new.html#NewVersion
hi Maciej,
I did an autotune and it maybe similar with your test. After I did autotune, it was perfect, but when I went to fly another day with a full battery 6s, the voltage was about 25v (higher than the voltage during autotune), it was very unstable. So this problem maybe result from battery voltage. During autotune, batt voltage is lower, and PID value from autotune is suitable at that time, but when use a full batt, those PID values become unsuitabe, accurately, too large.
How do think about that?
Thanks!
Eric
