Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Try first holding the safety switch down and powering up the hawk. If this fails backup your SDCard and format it Fat32 and then see if it doesn't completely the boot cycle. Try flashing back to 3.1.5 and connecting via console and do an setup/erase and setup/rest
I am having 'Compass variance error' since upgrade to 3.3.2. I was flying beta versions previously with no issue. The problem seems to be worsening as well.
Setup:
1000mm hexacopter, New Pixhawk (imu failure on previous one), CSG Shop M8N XL (primary GPS), Generic Neo-M7N, RFD900, 1.2 video tx, Frsky X8R rx, 900 mhz gps dog tracker
6s dual 8000mah batteries
AUW ~6kg
It gives no indication of failure at startup, but once I get off the ground in stabilize it will randomly do a roll pitch and then maybe give me a compass variance error and then do a large pitch or roll twitch. I can switch into alt. hold and pos. hold and it will do the same thing. The twitches are getting worse with each flight it seems. I tried recalibrating the compass with no improvement and I just tried switching to the 2nd gps compass (did calibration) and the same results. I'm not very experienced at log review and hope someone can help.
In this log I took off, saw a twitch, switched into alt. hold, pretty sure I heard the computer say 'compass variance error and then it pitched back and left pretty hard. I recovered and land ASAP.
TIA for help!
2015-12-05 15-45-07.bin
I found the issue but don't understand why. It is the Garmin Astro dog tracker and the 1.2 GHz video transmitter interacting. I was mistaken, the dog tracker is actually transmitting in the 151-154 MHz range. With the video transmitter and the dog tracker off I see no issues, same with the video tx off and dog tracker on - no problems. Both on and it twitches, sometimes severely. I believe the current drop is just a response to this and we see it go to 0 because I am only monitoring one of two battery inputs.
I tried moving the dog tracker all over the copter and it didn't help. I'm not really sure why this is happening at such different frequencies. Would love to hear any theories.
I only notice that your current had fairly periodic spikes to 0. Seems like periodic ESC glitch. Check your CURR pllot.
Have no idea for the reason.
Thanks for taking a look at the log! It does seem there is a power issue. I have a dual battery setup and I'm now wondering if one battery is loosing connection? They have separate power leads to the distro board and I only have one battery being monitored by diy power module. I have seen the compass variance error happen randomly with it just sitting on the ground not armed but I guess this could still be the issue. Guess that is where I will start looking.
Thanks again. Open to any other recommendations.
I would suggest disabling the internal compass as it doesn't use it anyway even if the external fails. FYI it may or may not have anything to do with 3.3. I have had to do the compass calibration and then the compass mot a couple times before I stopped getting that error even with 3.2. Did you re-do the compass calibration when you went to 3.3? It might juts be finicky like mine [ and many of them ] and unrelated to 3.3. But if your certain the external is fine might want to just disable the internal and issue solved.
I will give this a try but the current drops are still bothering me. What is strange is that the voltage doesn't really change, only the current dips. Also, compass 1 mag X and Y clearly show a deviation coincident with a current drop but compass 2 (pixhawk internal correct?) shows no deviation.
I have redone compass calibration and compass mot with no difference on both external compasses.
I've attached a screenshot that clearly shows the above and I have attached another log showing a longer flight with greater issues. This log is from the csgshop M8N XL, so this behavior is present with two different external compasses.
2015-12-02 13-48-59.bin
+1
When you say "on the ground" is this on concrete? I've seen rebar play havoc with the compass' and it goes away when I move it over to the grass..
Nope, on grass. Just weird because I've never had an issue like this before.
53
54
55
56
57
of 449 Next
