Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I will have to try it on my 250 quad
Did three auto tunes so far, reduced the suggested atc_accel parameters and the other parameter suggested in this thread( can't remember the name right now, but the one that was 0.5 instead of 0.1) each auto tune, was way too unstable, machine would take off, and wobble violently. last auto tune with the accel parms lowered was the least wobbly. Turned down stab rates by 1/3 and they are now closer to previous settings I had that flew well,( except in stronger winds)
So far 3.3 seems more solid in position hold.
Besides the auto tune problems, I can't get loiter and throttle pids to change. I change them, click write...and it reverts back.
Hi Nate892,
The next release candidate should fix your problem. Sorry about the hassle!!
Thanks for the response and hard work put in by you guys into the community.
Hi there,
Im trying to add px4flow(Lucas-Kanade method custom firmware) to pixhawk(3.3rc1) I think, Its work :)
I have two question about that;
1) Can I use Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow checking?
2) Which flight mode support optical flow? loiter, poshold, althold?
Hi guys,
I use px4flow with this firmware (http://ardupilot.com/downloads/?did=118) to pixhawk(AC 3.3 rc1) by i2c.
But it doesn't work. opt_m_x and opt_m_y are always zero.
Did i miss something?
The i2c address should be changed?
sorry for my English.
can you try power up by USB first.
@Alp,
Yes, optical flow should work although some more changes are coming to make it more reliable. It was demonstrated at NAB with the solo.. it's all the same code.
Only Loiter uses optical flow at the moment but that was a specfiic choice only because it's very new functionality I expect we will extend it to other flight modes like RTL in the future (it's very easy to extend to other flight modes).
Yes, I think the opt_m_x, y should show the raw output of the sensor.
Hi there,
My question:
1.Use USB connect PIX : I can in Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow .
2.Use Battery powered : Can't in Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow.
But only reset PIX . I can in Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow.
I am waiting for the uploading the 3.3 rc 1 from the MP. WHEN is this ready?
