Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Exactly, it looks to me very strange and suspicious cyclically, as if something had ended and began, a filter, a loop program ?. Once again, I checked the drive, and it can not be a better balance, carbon frame, rigid, propeller only 12 inches, engines E-max 3506 650kv, before I flew on 15 and 18 inch propellers and had less vibrations). Anyway, it's great, new soft, tests are needed
      I imagine this has more to do with the changes we've made in the filtering and accelerometer scaling.  AC3.3 is more resilient to high vibes but I wouldn't be surprised if it also shows vibration more accurately now.
      • Hi, thanks for the information. So, is it acceptable vibration standards will change? from + 3-3 and -5-15? Do I have to worry vibration level? Besides great work
        • We need to discuss this more before we can give new guidance on acceptable vibration levels in the logs.  This is early days in beta testing this new code still.
          My feeling at this point is that what you have in your log will be fine.  What is probably most important is that 90% of your data looks good, while 10% appears to be spiking outside the normal range.  If you're not having a problem, I suspect it will be fine.
  • It is a pleasure to help.
    https://www.dropbox.com/s/94qfz2plg5b9zif/log%20alien%201.rar?dl=0
    https://www.dropbox.com/s/31gnx0snx5mltri/log%20alien%202.rar?dl=0
    thanks
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
  • I would go for different led flashing and to let Pilot take the decision. For example green flashing would be 3d lock and good hdop, where solid green is best with all the New checks. The reason is simple mostly if you are outside with a lot freespace this will be not so important. Finally it should do fun it's a hobby it's not an Airbus....
  • Any chance you could rename this to 4.0! This would make a clear deviation between APM and PIxhawk.
    The reason I say this is that I was given an old apm 1.0 and it took we a lot of reading and a lot of time because I could not find where support was stopped for 1.0 -Lots of failed attempts to upload firmware and get mission planner to work and even when I had a copy that kind of worked I kept wondering if I had the best one or an early one.
    For first timers this would make life a lot easier.
    • Plus 10 !!  Yes I think it should named 4.0 just the facts .. dropped APM Also EKF on as default ..etc .. as you guys say there has been a lot of changes .. why not let APM 8bit have .. 3.2.1...2..3..4..5..  etc and 32bit controllers Have 4.0 ...1..2..3..4 etc
    • That would be a great idea.
      I think its ok to go for a new major relase just because you drop APM support.
      ATM it is allready confusing which Mission Planner works best with which firmware.
      Cheers
      Axel
  • Is RC2 still in time for upcoming weekend?
