Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Igor,
I think Zeal pads are probably ok as well. I haven't used them personally but I've heard some good things.
Can you have over damped solution? I have
and zeal under it and flight controller attach with hobbyking Flight Controller Mounting Pad
Andrei,
We've seen these "whiskers" in a few logs including on one of my IRISs. They only appear on the MPU6k accelerometers and only on AC3.3 (i.e. not on AC3.2.1). There's a growing sense in the dev team that we've got either a software bug or a weird physical effect. We're going to need to get to the bottom of this issue before we release AC3.3.
Thanks for these logs.
I'd say something is loose due to all 3 axes exhibiting vibration same order harmonics, also high Z compass offset. Note high RCout as well.
This morning I tested 3.3-rc3 in Guided mode for the first time. I used dronekit-python and an Iris+. I was able to arm and takeoff, however, despite giving an altitude of 5m in the takeoff command, the Iris climbed to only about 10cm. On a second attempt, it climbed to about 1m.
We then reverted to 3.2.1 and ran the same script. During takeoff, it climbed to ~5m as instructed (and as it always had before when testing).
Any ideas why it isn't climbing properly using 3.3-rc3? I should mention that all three tests were done in the same location with a clear view of the sky and large numbers of sats.
Our need for 3.3-rc3 at the moment is the SET_POSITION_TARGET_LOCAL_NED message which isn't supported in 3.2.1. We would really like to get this figured out so we can move on with our project.
Thanks for any insights.
David,
I'll answer this over on the drones-discuss or gitter threads 'cuz you've posted there as well and it's really more of a developer question,
Mike
Henri, I'll reply at the latest part of this thread rather than back here on page 42.
I had similar problem and received the following reply yesterday:
http://diydrones.com/xn/detail/705844:Comment:1985502
in essence:
EKF check gives the same pre-arm messages (need 3D lock) but it refers a different, newly introduced pre-arm check.
Did you power and an wait for a GPS lock tone before arming and lifting off? That is something new to version 3.3.
410
411
412
413
414
of 449 Next
