Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Hi Leonard,
            Ok I'll give it a shot, enter the values for MOT_THST, leave the Autotune results like they are, and reduce RC_Feel, with RC5, and fly today..
            Thanks for your feedback...
            Erik
    • When you say a swim you mean the copter got completely wet aka crashed in the water? I thought that ruined the baro sensor... maybe not?
      • Hi Richard,
        It was completely submerged, but after taking all components apart, to dry with a hot air dryer, it seems that all electronics survived. just lost one Motor which was smoking when I took it out, including the corresponding ESC.
        • Your fast actions probably saved it. I wish I knew of a type of fuse that would open if it detects water. It would be nice if the lipo was instantly disconnected if the copter crashed into the drink. It would probably save the esc's too. I think I'll research it a bit. Gotta be something.
          • Yep, if there is anything available to control the gate of an BTS555 which I am using as master switch for all Power on the HEX that would be great.
            Currently I am pulling the gate down to ground with a low voltage switch.., and if that can be replaced with something that "smells" water that would save electronics.
            On the other end you'll still need to take everything apart to dry it out, so it's better not to drop in water at all..
            That's rather difficult in the Netherlands, too much water all around... ;-)
      • I didn't understand that statement as well. What is that "resent swim" supposed to mean?
        • Hi Alex,
          See page 11
          • Checked it just now. I remembered that incident as soon as I started reading it.
            So it is still flying!..:)
    • I had exactly this issue with 3.2-rc14 the drone was over responsive after the Autotune.
      I started this threat in December 2014:
      after doing the AutoTune the drone becomes too responsive (over sen...
      Mabe Autotune is not recommended for all frame sizes and does work quite well for some of them!?
  • For me I also think that autotune is giving not the best results for my T960: The difference in reaction between roll and pitch seems to be significant. At the moment I think I must do every axis with another aggressivness.
    Autotune_AGGR 0,1: Overall Motor Vibrations and oscilating rcout on M5 and M6
    Autotune_AGGR 0,07: No vibrations, Roll to sensitive, Pitch to weak, Yaw terrible (Large overshots)
    Next I will try Roll on 0,06 Pitch on 0,08 and Yaw on 0,09.
    But I will wait till the next RC or may the final.
    Maybe this will give the same performance on each axis.
    Sorry the logs are to big, and on my laptop. I will try to sent them later via link.
    Cheers Gregor
