Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Geert,
So I wrote down the numbers for each prop size from 4 different manufactures. Some sizes don't have much data but here it is.
0.45 to 0.55 is for 5" props
0.62 to 0.65 is for 6" props
0.66 to 0.68 is for 7" props
0.66 to 0.70 is for 8" props
0.67 to 0.67 is for 9" props
0.64 to 0.70 is for 10" props
0.70 to 0.75 is for 11" props
0.73 to 0.78 is for 12" props
0.72 to 0.77 is for 13" props
0.71 to 0.77 is for 14" props
0.70 to 0.76 is for 15" props
0.70 to 0.76 is for 16" props
0.68 to 0.62 is for 17" props
0.68 to 0.75 is for 18" props
So for my copters I am going to go with:
0.65 is for 5" props
0.65 is for 6" props (I think the low numbers come from flexing props and I use HQ and they are stiffer than normal)
0.675 is for 10" props
0.725 is for 11" props
0.75 is for 12" props
0.75 for 16" props
0.75 for 18" props
As you can see, the data moves around a bit and changes a lot for different manufactures and maximum power level of the motors.
I am running 12-5 props.. I haven't done auto-tune, it is always windy it seems when I have the time and chance.
I like manual, because If I can learn that, It would be valuable knowledge.
Richard
Ok, Start out by setting these parameters.
MOT_THST_BAT_MAX,25.2
MOT_THST_BAT_MIN,21
MOT_THST_EXPO,0.7
MOT_THST_MAX,0.95
To do a manual tune you want the feed forward off
ATC_RATE_FF_ENAB,0
Very carefully take off and gently make sure you have control over your copter. Start with tests at small angles like 5 degrees and work up to 20 degrees slowly. The way I do each test is I move the stick smoothly to the desired angle then let it spring back quickly. Check both roll and pitch this way.
Set your Rate D term on your slider. Set the lower limit to your current setting and your upper limit to 4 times your current setting. Do 20 degree tests above and listen for oscillation. If you can increase it all the way to maximum, set that as the minimum and the maximum 4 times this and repeat. If you get an oscillation that looks like it might cause you to crash then simply move your slider all the way back to minimum.
When you have found the point where the copter just starts to oscillate, back off so it just stops oscillating. Look at the value in mission planner and write it down.
Now set your tuning slider to Rate P. If you don't do this now you will overwrite the value you enter for Rate D.
Reduce the number you wrote down by 25% and enter it into Rate D.
Repeat this process for Rate P. When you are done change to Stab P and set both Rate P and I equal to the value you wrote down less 25%.
Repeat the same process for Stab P.
This won't give you a tune as good as autotune but it will be ok.
Now once you have tune Roll and Pitch like this you can use the input shaping to soften the feel if you like.
Set
ATC_RATE_FF_ENAB,1
ATC_ACCEL_P_MAX,11000
ATC_ACCEL_R_MAX,11000
if you see your copter overshoot from a 40 degree test then you will need to decrease ATC_ACCEL_X_MAX. You may then decrease it further until you get the feel you like.
If you want to tune Yaw then I really suggest giving autotune a go.
Be very careful at all times during this process. On early flights just lift off by 20cm to make sure it is flying well. That way you can drop it onto the grass by cutting the throttle if you need to.
Let me know if you have any further questions.
Hi Leonard
I seem to have a problem initiating the auto tune mode.
ON a great calm morning yesterday, I tried to do the auto-tune.
I have a switch assigned in the setup to use RC 7 and confirm in the radio setup that for channel 7, that it is going from the full low to full high pwm values when I operate the switch. (980 to 1980 approx)
I don't get feedback in the flight modes in MP that I am going to auto-tune when I operate the switch..
Should I?
I have made sure my trims are centered. I flew in calm air and switched into ALT hold at about 20 feet.
I flipped the switch and nothing happened. Am I missing something that i need to do, and or is there a way to verify while still on the ground that it is going to go to auto-tune when I flip the switch?
Thanks a much Leonardthall
After reading all that, I am reconsidering, using the auto-tune might be the way to go.
I have set the switch before to do an auto-tune and it seemed to be right, but when I went into the air and used the switch, it didn't do anything. I read later that if there was any trim, it wouldn't start.
It is possible I had a click of trim in. I made sure all my trims were nuetral and will try it again.
Is there a way to confirm that auto-tune is set up correctly before the flight?
With Mission planner, I can always confirm flight modes, but what about AutoTune?
RE
I tried 'Follow Me' tonight. The quadcopter was quite jerky when adjusting it's position relative to my location. Is there a new setting that makes for more smooth yaw etc. when using 'Follow Me'? This was after a new Auto Tune on rc5.
In Basic Tuning there is a slider for pitch/roll sensitivity. Would sliding that left make things smoother?
I did a few more tests with rc5 and the RCMAP changes. RCMAP works great as reported elsewhere. Couple of things I noticed:
1. I cannot arm in Auto. GCS says "Press safety switch" but the switch is already pressed!
2. If I arm in another mode, switch to Auto and then try and run a mission starting from the ground, when I raise the throttle the copter immediately heads towards the first waypoint from the ground, rather than climbing to a safe distance and then heading towards the waypoint. I was in long grass and cut a swathe through it before it got to a safe height!
I've not tried either of these before so not sure if they are new to 3.3, but both seem like bugs.
Not sure if there was an intended change in arming check but it appears that the safety switch check not always performed.
RC5: in loiter GPS lock but compass issue (indoor testing), I can arm before enabling with the safety switch (ground station indication "armed") and due to EKF variance it immediately switches to LAND mode. So actually the FC interprets the status as ARMED too. Motors are not spinning - so the switch still does its job.
357
358
359
360
361
of 449 Next
