Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Lijingwei,
This has two issues. The first is your copter is under powered. The second is your tune is not as stable as it could be. You hit the copter with a roll command and it then struggles to keep control. The act of decreasing some of the motors and increasing others means that it can no longer keep the average throttle high enough to maintain altitude.
I would suggest reducing ATC_ACCEL_R_MAX and ATC_ACCEL_P_MAX to 72000 and doing an autotune.
Question for check: 72000 or 720000?
In description on _YAW_ 720000 = disabled.
Hi Aleksey,
I did mean 72000.
From what I can see it says:
Values: 0:Disabled, 72000:Slow, 108000:Medium, 162000:Fast
Hello
what is actually the most stable FW-version that I can use in a "productive" copter?
Hi Jin'
The answer to that question is always the last official release.
ok, but i read also about bad problems with 3.2.1
and i also have problems with 3.2.1
- alt hold jumps
- or it randomly rolls without command
in the log i see a roll command from the imu, but not from the desired roll
the vibrations are way lower than suggested :
I am interested to hear what problems 3.2.1 has. You need to be careful looking at the problems people are having because people tend to make a lot of noise talking about their problems but say very little after it is pointed out it was caused by a mechanical failure or setup problem. Our logging is so extensive that we can see pretty much exactly what the controller is doing at any given time. The only thing we really need to make educated guesses about is the external disturbances and mechanical/electrical problems. Maybe 1 in 100 basic stabilize/alt_hold issues turn out to be caused by problems with the controller now days.
I would be interested to see a log demonstrating your problems as I have not seen anything remotely like this for years.
I hope I can help you with your issues. I just need a log.
ok, for example this one: gps turns off(?) after starting in acro then loiter doesnt work, gps errors happen, and this is always, i can not use rtl or loiter because it just flies away when i activate it.
acc and mag are calibrated (several times - same results - seems ok)
what can this log tell me? please would you be so kind to "translate" it for me?
2.BIN
Hi Jin,
Well, it looks like you are right. It looks like you have completely lost contact with the GPS. From the logs I can't say if it has lost power or just lost the data link to the gps. I can't see any sign that your compass has a similar problem so that makes me think it is just the data link to the gps that has gone. (assuming you are using a 3dr compass/gps module)
I would be checking my connector between GPS and Pixhawk. I would replace it if possible and try again.
hmmm, it looks like a ... brownout(?)
now i just soldered a 22µ directly on the power line of the gps module and it looks... better:
1.BIN
