Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I have telemetry radio connected to Telem 1 and minimOSD to Telem 2. Is that what you mean? With 3.2.1 in PH. I'll double check if data is coming.Regarding second GPS... is that the picture you are looking for?
I notice on my logs that there is a period at the start where EKF innovations are all at 0. After arming they start reading but when I see other logs there seems to be data all the time.
All IMU data and Mag seems fine to me. It also seems that the various EKF readings sit at zero and suddenly start logging.
This only happens with 3.3rc5 and all of my machines. Any ideas!
2015-06-02 17-04-24 Cinetank EKF Variance.log
I have had a problem whith the landing detector not working in some modes. I remember landing in loiter with 3.2.1 and it disarmed.With 3.3 rc 5 and before I haven't had a landing disarm in loiter or alt hold. I try not to land in stabilize if i don't have to ;)
It works perfectly in an auto landing, but not in loiter or alt-hold.
2015-06-09 20-06-58.bin
Hi Lenard,
I know whats going on. I just looked at the code and it only disarms in an auto land. I thought it would disarm in other modes. So. lading detector works, it just only disarms in land mode. Is there a reason we do it this way ?
Hi Greg,
Cool, I understand. You thought it would disarm without touching the Yaw stick.
Greg,
It should automatically disarm in about 15 seconds if the pilot doesn't do the regular full left yaw, throttle-down maneuver. It's 15 seconds because some people want to take-off again.
I guess it would have been good to test AC3.2.1 first instead of jumping to AC3.3 'cuz really we're looking for AC3.3 specific issues on this thread.
Hi Greg,
From what I can see in your logs, your copter has landed and dropped to throttle_when_armed throttle output and is waiting for a disarm command from your yaw sticks.
You aren't logging RC IN and OUT so I can't see what you are doing. But it should be working.
If you set your log bit-mask to 157694 it should give us a little more information.
Tried 3.3rc5 on f450 frame. Everything was great. Copter is better than ever before. Thanks a lot.
The only slight problem is landing. When I put it in land mode, it bumps againt ground twice before settling in.
Can I fix it in configuration?
Here is a video showing the issue
https://youtu.be/yIw9ItuQB_g
log is attached.
2015-06-10 06-29-15.bin
sorry the video is here
http://youtu.be/NHxnhOxDDyw
and if you see the final fall when it actually lands is quite fast.
Hi Pritam,
This is the classic baro getting disturbed by the high pressure bubble created by the props as you get close to the ground.
Classic designs that are badly effected by this are copters with canopies covering the pixhawk that are open on the bottom. The best design for landing altitude estimation would be something like a bucket. So a completly enclosed fuselage with openings on the side near the top.
You can see from the image below that the baro is dragging the altitude estimate down faster than the copter is traveling down causing the copter to lift off again.
