Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Hi, on friday 26.6. I updated from RC 5 to RC 6.
        I changed only the values P Pitch from 13.700000 after Autotune to P 9.740000 (the same value from Roll)
        The Hexacopter has FC Pixhawk 3DR, DJI motors 2312 with esc 420 S and lipo 4S 5000 mAh, time of flight was 12 minutes - without any problems !!!!!!
        Flight modes: Stabilized, AltHold, Loiter, PosHold, Circle, Land, RTL
        enclosed you find the logs
        2015-06-27 16-10-06.zip
        https://storage.ning.com/topology/rest/1.0/file/get/3702706418?profile=original
      • report was doubled
      • Changed droneshare settings. Maybe now? I did change back. Btw, why p limit in mp is 0.2? 0.35 on mine seems to be ok..?
          Hi Kuisma,
          Rate D is limited at the lower end to 0.002.
          I think I see the problem.... maybe.... It looks like the release went out with AUTOTUNE_AGGR set to 0.05. This tends to be a little sensitive, the default should be 0.1.
          Thanks!!!
          • Thanks for the tip. I changed aggr to 0.1 and did another autotune. Now pitch seems ok, but roll is still quite bad. Lot's of wobble and quite sluggish. Yaw feels quite aggressive but it works. Oh, when in stab mode and doing yaw, copter gained quite a lot altitude. This didn't happen in althold mode.
            new results:
            stab roll & pitch: 6.25, 10.95
            rate roll
            0.08
            0.21
            0.002
            500
            rate pitch
            0.26
            0.63
            0.012
            500
            yaw
            0.65
            0.065
            0
            100
            Strangely lot difference in roll and pitch?
            log: http://www.droneshare.com/mission/84513
            pic of the quad: http://imgur.com/USASeBr
            It's 700mm.
              Hi Kuisma,
              Yeh, roll is still messed up. The good news is your problem is specifically what the latest changes to autotune are designed to fix. (Rate noise during the test)
              To dampen down your Yaw control I would suggest turning on feed forward and using your acceleration parameters. A good starting point is:
              ATC_ACCEL_P_MAX,110000
              ATC_ACCEL_R_MAX,110000
              ATC_ACCEL_Y_MAX,36000
              ATC_RATE_FF_ENAB,1
              If the FF is set to 1 then Autotune will set them at the maximum your copter can handle.
              • Forgot to set those parameters, but tested autotune today with latest firmware. Now it seems to be working ok. Though I think controls are quite a lot softer than with earlier (3.2 or 3.1.5, don't remember which I used to tune it earlier) autotune version.
                this time I got
                Roll
                9.2
                0.20.49
                0.009
                Pitch
                6.5
                0.24
                0.6
                0.012
                Yaw
                4.3
                0.57
                0.057
                0
                log: http://www.droneshare.com/mission/85358
                  Hi VP Kuisma,
                  That is more like it.
                  Yes it should be a little lower in the D term and P compared to the old Autotune. The old autotune targeted a small amount of overshoot, the new one is targeting perfection. This should mean a slightly more locked in copter.... But we are really splitting hairs here now.
                  Thanks for the feedback!!!!
              • Leonard, this was something i was not knowing. Activating ATC and FF will be considered during autotune and set to max the copter can handle ? if it's so this is pretty cool!
                As i'm flying almost acro i haven't enabled ATC and FF but considered the benfits i'll give it a try....
                  Cool, Thanks Pomaroli!!
                  I will be very interested to hear your feedback!!
                  With the next autotune, I hope you will get a nice tune and close to maximum acceleration parameters.
