Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
currently i'm running a pixhawk on ac3.2 firmware.
I'm interested on using this ac 3.3, but it has been rolling from rc1 through rc6 and still on beta version.
Is it save for me using this ac 3.3 rc6 now? I'm not a newbie but nor an expert as well.
arga,
No, -rc6 is not safe it seems so best to at least wait for -rc7.
Hi Winston,
I have been looking at your log. Repost your issue then reply with a link and I will chat to you there.
Thanks Leonardthall!
Winston,
Sorry about your crash. This looks like an AC3.2.1 log.. Please remember this is the AC3.3-beta testing thread. I know it's hard to find support sometimes but it muddies the waters to post this here.
I apologize Randy, is that yesterday I was flying with Arducopter 3,3-rc5 and thought I could post the problem here, though I'm sure it was not a firmware problem ..
Sorry ...
Winston,
Nah, I shouldn't be such a stickler especially considering in this case you sacrificed a copter during beta testing. Hopefully Leonard can sort you out, if he needs backup I'll have a look.
Robert, Winston,
Very sorry about your crashes.
I've looked at your logs and it looks like the EKF's coming up with bad attitude estimates for roll, pitch and yaw - or at least they inconsistent with the older DCM by >10degrees. This is likely what's causing the out-of-control feeling you're getting. Obviously this is pretty serious so I've posted a warning above to ask people to stay on -rc5 until we figure out what's going wrong and publish fixes. Worst case we will roll-back to -rc5 until we figure it out.
RobL had an issue with his helicopter as well and during that analysis Paul mentioned there was a change in the gyro offset learning - that would be consistent with this problem.
Really sorry again, hopefully this will help us get to the bottom of the problem soon.
Yes, something is badly wrong! If you plot the learned offsets against the compass inconsistencies you can see that the learned offsets vary hugely and almost randomly. You can also see that the inconsistencies rise with the variation. (I'm not sure if it's relevant but I see a similar oscillation but on a much smaller scale with rc5 and EKF_GBIAS_PNOISE set to 10x it's default)
