Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
On RC5 that works fine ;o)
Regards.
Alberto
Can I test to retract without arming for testing purpose ? Cause I have all connected and configured my ch8 but nothing happened on the ground. I haven't flyed with this new frame yet
Sure you can.
As I have a Tarot650 Sport sitting in it's bag with gear up, the first thing I do when I connect a battery is gear down without arming.
Also, the first thing I did was to connect the gear directly to the receiver to be sure it's working OK.
I did had some problems, as the manual was nonexistant, but after I sorted that out, it was easy to set them with 3.3.
Ok, after more investigation, my brand new landing gear controler is simply death...
Thanks you for your help, really .
maybe is something wrong with wires..
Yup, works great for me :) I'm using the standard tarot retract controller from the 650sport (which I believe also comes with most of their other current frames). The only thing it doesn't do as advertised is to automatically retract the gear after takeoff, it has to be retracted by rc switch. But it always deploys for me automatically when landing or rtl.
Copter-3.3-rc7 should be available through the mission planner's beta firmware link in about an hour.
We think this at least partially resolves the attitude estimation problems that Winston, RobertS and Peter Barker (on another thread) found. Still, we recommend staying on -rc5 until we've had more time to be sure. We're pushing out this version because we believe it's safer than leaving a clearly broken -rc6 in place.
If you do feel brave enough to test -rc7 please be on the lookout for attitude estimation errors especially in the first minute of flight.
Changes since AC3.3-rc6:
1) reduce EKF gyro bias uncertainty that caused attitude estimate errors
2) force 400hz IMU logging on (temporary for release candidate testing)
Sincere apologies for the troubles and thanks for helping us test so these types of troubles don't spill out into the larger community!
Hi Randy,
I had two successful flights with rc6. The second however started a little strange: After arming and while still on the ground, the copter showed massive wobbles/oscillations - similar as with wrong PIDs. Then after disarming and arming again all was fine. Sounds like it is related. Send me a PM if you are interested in the log.
Best regards,
Thorsten
Hi Randy,
I guess I will be surprised if this is actually the source of the problem. I am running rc5 with close to these values (1e5 rather than 8e6 in GBIAS_PNOISE) and I don't see this massive oscillation. Here is a graph from wednesday with rc5. You can see that the overall changes are very small and the oscillation occurs around a mean that looks close to what you actually want. I suppose the increase in uncertainty could be the culprit (I didn't change the default), maybe the initial perturbation throws everything off? If it stop raining I might experiment a little to get more data.
So I ran tests with rc7 with GBIAS_PNOISE set to 1e5, 8e6 and 1e6 respsectively. I can't say that rc7 felt any different to rc5. The learned offsets looked pretty similar to what I was getting with rc5 and control seemed good.
It was fairly gusty but the copter coped fine and the EKF innovations seemed ok. I couldn't see any difference in roll/pitch/yaw between DCM and EKF. The logs are pretty large because of the IMU logging so I won't post here. I guess a theory might be if you have high vibrations then you will be more susceptible to bad gyro bias learning.
I did notice two unrelated things:
1. You can't set GBIAS_PNOISE in tower, it thinks the value is effectively 0.
2. I still see very aggresive throttle up with RCMAP. Spin on arming does not work for me and as soon as I touch the throttle the thing tries to take off.
Graphs below. Let me know if you want me to plot anything else.
