Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • 2+ years ago when we first saw a dude turn his dead cat into a quad most of us were appalled, but it started a whole genra of frames and frame conversions. Whilst I find it in poor taste I don't find it any more odd then someone taking their dead pet to a taxidermist.
      • Obliviously its not that bad then. Then it would be nice to see a radio controlled parrot designed with some gyro  and counter rotating propellers so it can run on 1 propeller ax from its head.
    • People (governments) are using drones to slaughter entire villages, so the cat thing is really nothing..  God and Drones have nothing to do w/ each other.  (I wouldn't do that to my dead pet, but there are all sorts of people in this world!)
      (And, this is more of a technical info forum.. Go to rcgroups drone section for random chit-chat)
  • I noticed with RC8 that after a while a get a fast flashing green light which would indicate low hdop I'm assuming.
    I also found it a pain when scripting a number of missions that I needed to constantly switch flight modes because the copter would not arm in Auto Mode.  I was using Tower to quickly load different flight plans and just needed to have them run only to have to walk over to my RC transmitter and flip the switch so it would not be in Auto Mode.  I could have pushed a button on the tablet I suppose but it seem faster to flip a switch.
    Mike
    • I was under the impression you couldn't arm in auto mode anyway, can't in 3.2.1 as it's designed that way.
      • I know but it would be nice if your just using a GCS and what to fly a number of missions that at the end of the mission it would switch back to Loiter or Stabilize once it lands so I can just lock and load.
          Yes, the the fast flashing green LED is a good thing.  It means the GPS has SBAS so it's precision should be better.  We will definitely add this to the LED description wiki page before the official release.  Sorry for missing this in the release notes.
          Yes, not allowing arming in Auto and not switching out of AUTO at the end of a mission are safety features to stop accidental takeoffs and to reduce accidents caused by the pilot not knowing what flight mode the vehicle is in.
  • I tried rc8 on my 250 size quad. Althold, poshold, loiter, rtl is ok. and also I have tried flip, everything looks good in my opinion
    Only flip mode needs fine tuning on my 250 size quad
  • I upgrade to RC8,have  few questions,
    why "Throttle Accel" & "Throttle Rate" these two items can't make change??
    3702058568?profile=original
    last night I down my Mini Hexacopter with "Autotune",take about 11 mins,when I land battery voltage only left 3.4V...
    why take so long to do this autotune? here is my autotune result
    3702058100?profile=original
      Thanks for testing.
      The MP still needs to be updated a bit more to match the parameter name changes for AC3.3.  I'll remind Michael so hopefully he'll get to it soon.
      The AutoTune takes more time because it does Yaw now as well.  The AutoTune wiki page has new instructions to allow tuning a reduced set.  For the next release (AC3.4) we will likely add a better autotune interface to the ground stations to make this easier.
