Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi Wes,
      Not a bad idea on the minimum throttle thing. On its own it may not be up to scratch but I will think about it.....
      • I believe this is another scenario of "GPS-correction overriding pilot input". In my case I fly with rc8. My copter triggers battery failsafe LAND mode. GPS quality is very bad. It leans forward by itself regardless of my full-pitch-back input. I am confused at that time as LAND mode should accept my pilot X-Y correction but it doesn't. This case is discussed here and is not arrive to a solution yet.
        Wes's proposal is stop listening to GPS when (flight_mode == loiter) and (throttle_input == min)
        Mine proposal is stop listening to GPS when (flight_mode == land) and ( (pitch_input != centre) || (roll_input != centre) )
        I think in general, autopilot should stop listening to GPS correction when there are input from pilot. Give pilot control the highest priority. Maybe position-hold mode is already doing this?
      • Wether it be a minimum throttle GPS lock out or an instant yaw command to make an already landed multi stay put, I would be happy either way. I just don't want to have to take my fingers off the control sticks to make it happen.
        This last tip over was a complicated landing on a small concrete square three feet from my wife's car. It was windy and and the barometer pressure was changing a lot with the gusty conditions requiring constant throttle changes. This is why I did not reach up to switch to AltHld to land as I normally do. There was more than enough going on already.
        In any case a more robust method to prevent tip overs on landing would be much appreciated, thank you for giving it some consideration!
        • motor kill switch.
          One of my big, easy to reach switch is motor stop.  As SOON as I am on the ground, or sometimes even just above, I hit the switch and hold it until it disarms.
          Yes, ideally the auto detection would work better, but for now the kill switch works.
          • But it requires you use up a channel just for landing. It also means you are reaching for a switch during the most tricky phase.
      Wes,
      Nice to see you're getting very familiar with the logs.  I think you're correct that the landing-detector didn't yet think the vehicle was landed so the vehicle was still trying to move horizontally.
      Switching to AltHold when the throttle is all the way down works in some situations but it wouldn't be good if the vehicle was 100m up in the air and the user was just trying to descend at the maximum speed.
      It's quite difficult to get the landing detector so that it can always detect a landing quickly but never have a false positive.  We've done a fair bit of work in this area in AC3.3, it's possible we can do more (for AC3.4 or a patch release) but I'm starting to think we may need a range finder to get to the next level of reliability.
      • I would think it is more dangerous to have a multi try to move after it is on the ground, (I had to fight the urge to reach out and try to stop it from going over), then to have the muti drift while decending under control.
        A false positive on the landing detector would be bad. Loosing GPS hold momentarily not so bad. Personally,I don't try to descent at minimum throttle but low throttle.
        A minimum throttle GPS lock out would be great for me, maybe a check box to allow GPS lock so that those who want the feature could try and those that don't won't have to.
        Using a range finder is a great idea also, would require every body to add another sensor to there machines- I would do it! I have a PX4flow sensor on the shelf that is just waiting to be played with.
        Adding a minimum throttle GPS lock out option might even be worthy of summitting a formal feature request. Have to wait and see if any one else things it might be a good idea.
        • I think this would be bad for landing in windy scenarios when PosHold/Loiter is most useful. There would be the danger that the craft would suddenly get blown sideways when the GPS was ignored.
          I wonder whether low-tech is best here. I have advocated ignoring yaw commands when throttle is at minimum in these modes so that you don't end up doing the disarm dance while the copter still thinks its flying. Why not instead of everyone switching to stab when they are on the ground have some "I've landed dance" so that the FC knows to basically shut down. e.g. if you are ignoring yaw at min throttle take full right yaw as "copter on the ground".
          • Yes I second
            • Aargh I absolutely hate this forum software. Seriously, was it designed in the 1980s? It randomly truncates replies to three words - usually the longer you spend composing the more likely it is to truncate. And why do we have a single thread with thousands of replies in a disorganised mess for such a wide topic? Why not have a separate area/forum for testing where we can have sensible threaded discussions about a single issue, like landing, or gps, or ekf, or autotune, etc etc that people can actually find, report, discuss, contribute to and come up with solutions for issues rather than each issue being lost and forgotten in the hundreds of pages of replies.
              Anyway, I had composed an eloquent soliloquy on landing issues which I won't bore myself with again, but it boils down to:
              - Cautious landing detector good, false positives and falling out of the sky bad.
              - Landing detector not always great at detecting landing in good time, causing tipovers and mangled blades.
              - An option to 'assist' or 'tell' the landing detector that the craft has actually landed would be a great addition, either using some wierd and wonderful three finger salute or by a channel switch.
              - I use a popular tarot 650sport frame which by the time you add motors and batteries is top heavy and inherently unstable in landing, prone to tipping over (as are a lot of multicopters). Extending the landing feet/rods helps considerably, I actually use pool noodles/pipe insulators to wrap around the landing rods as I land on water sometimes. With the large landing feet and hence more stable craft I've never had a tipover and the landing detector seems to work much more reliably.
              - Landing in an assisted mode (landing/althold/loiter) is safer for the vast majority of flyers, landing in stabilize should be a last resort/experts only. But landing in stabilize is the most reliable/safest from the moment it's actually touched down.
