Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        Greg,
        Thanks for testing.  The flight looks pretty ok - hard to see the toiletbowling so maybe that's another log or perhaps it's very subtle.  The heading estimates from DCM and EKF appear to stay within 10degrees of each other and the ATT's ErrYaw is always quite low (0.15) so it shouldn't be toilet bowling much.
        I don't have any extra advice for the M8N, perhaps others do.
  • Using 3.3rc8 I'm getting and error in Mission Planner - Error Compass Variance
    Seems like others have seen this issue, but I've not found a solution yet in this thread. Is there a fix for this problem, or is this recognized as a problem yet?
    Thanks,
    Scott...
      If you have some dataflash logs that would be good as well.  I've seen this compass variance come up a few times as well on the thread but so far, no logs!  Best to set Logging-while-disarmed checked in the LOG_BITMASK selector in MP.
    • When you get your error compass variance messages usually your pixhawk will have a flashing yellow LED. Pick up your copter and move it a little bit. This usually fixes the error and allows the pixhawk to arm and continue a normal flight. This is the only workaround I have found for this problem aside from removing power and plugging it back in until a fix can be produced.
  • When do you plan to fix this? This is easy. Annoying to see it every time ...
    3702068752?profile=original
    • Yah it's been that way for a while and should be an easy fix for Mr. Osborne but I have a feeling he has his hands full just keeping up with all the changes in the RC firmwares :)
  • ArduCopter 3.3 rc8
    What is the correct value to put in FLTMODE1,2,3,4,5,6 for obtain Auto-Tune-Flight-Mode?
    I see that:
    0:Stabilize 1:Acro 2:AltHold 3:Auto 4:Guided 5:Loiter 6:RTL 7:Circle 9:Land 10:OF_Loiter 11:Drift 13:Sport 16:PosHold
    Maybe autotune is 8, or maybe 12, or 14, or 15?
    I know that you can not do by using the GUI in the planner, but you can only do by editing the "Full Parameter List".
    I also know that I can set AutoTune by CH7. But I do not want to do it by CH7. I would like to test it by using only a 6CH radio.
    • It is not a flight mode at all. You need to set it to either channel 7 or channel 8. oh looks like it is possible now with 3.3 and the new MP
        Yes, that's right.  It is actually a flight mode in AC3.3 (in AC3.2.1 it was not a flight mode).
