Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Here is my latest 3.3rc9 log
    yes it is a tricopter and here is the bird:
    yaw is better than with rc8, but still much worse than with 3.2.1
    p.s. disregard clipping, this is due to unintentional touch-n-go-es :)
    my only concern is that for some reason  all of my logs have "shifted" vibrations.... to be more precise vibrations are not under +/-3 with center at 0, but +/- 2 or less with a center at 1-2 for x/y
    2015-08-21 14-06-51.bin
  • Had my first with RC9 this morning, was very stable in moderately windy conditions. Alt-Hold, Pos-Hold, Loiter worked very well. Landing gears were functional running it through the Pixhawk. Telemetry to the Taranis was an awesome addition. Total flight time with autotune was 25 minutes. Had switches setup for RTL and Land and those worked fine, I also had a switch for simple mode and that is a very nicely added bonus. Thank you for giving us the ability to use all the additional channels on the Taranis, I'm using 14 channels through S.Bus.
    Great work guys!
    https://youtu.be/ZSzgQAV6TGY
    • Did you have to set the serial 2  protocol to 3 as mentioned above in red? I'm still on 3.2 because I couldn't get my taranis script to run right on 3.3. Maybe it's fixed??
      • I set the protocol to 4 for S.Bus, 3 didn't work for me either so I went back to 4 and it worked great.
  • Well RC9 is really good at first sight.
    On a small 500 millimeters quad without even trying to adjust anything such as accel calibration or whatever from RC8 it is a dream!
    It just works the way it was supposed to! Beautiful!
    Have a look at the attached very short flight vibes with all flying modes I'm using.
    Will load today RC9 on a much larger hexa and will give it a good test.
    Congrats to the dev team for such amazing release.
    Henri
  • Yesterday i installed RC9 and made the test again, that i made with my AUAV-X2 and -rc8:
    The Test was indoor, no flight, only power ON.
    LogWhenDisarmed = ENABLED
    Result with rc8:
    When powered over USB the log gives a 5 (00000101b) on Powr/Flags.
    When powered with battery the log gives a 7 (00000111b)on Powr/Flags.
    Result with rc9:
    When powered with battery the log gives a 5 (00000101b) on Powr/Flags.
    That means, the Bit for USB_CONNECTED is also with rc9 always "1".
    It seems, the problem is also in rc9 NOT solved...
    • it does not seem to matter what is in those flags. set battery failsafe for your voltage and see if it triggers on correctly, after pre-arm checks completes.
      mine worked fine.
      • OK, i will test it tomorrow.
