Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                  Paul,
                  I just reviewed the commits and as far as I can see we haven't made any changes to the GPS code between -rc9 and -rc10.  Just in case anyone wants to check (now or for future reference) the list of commits can be seen here and the changes in -rc10 are all the things after the "Copter: version to AC3.3-rc9" commit.  The first part of the description describes the area of the code change and there's no "GPS:" changes.
                  I've looked at the logs and, like you, I also see the constant changing back and forth between GPSs (see "U" field in GPS and GPS2 messages) which we know leads to ugly shifts in position although I don't directly see the impact of these shifts on the EKF innovations or vehicle lean angles.  Still, to be honest, it's the first time I've really looked for them.  I suspect you're right that this is the cause.
                  So a couple of suggestions/comments:
                  • Try disabling one of the GPSs (GPS_TYPE2 = 0)
                  • Try disabling some of the satellite types (i.e. set GPS_GNSS_MODE to "3" to enable only GPS and SBAS).  I've updated the param descriptions so bitmasks should appear in the mission planner's Advanced Config page for this parameter eventually.
                  • Try using u-center to increase the GPS's Baud rate.  This is very speculative and not evidence-based but I've heard from Michael Du Breuil that when we have a lot of satellites the 38400 baud rate is not enough to get all the satellite info from the GPS to the flight controller.  I know this sounds scary and important so let me follow up with Michael.  From what I see in your logs all the GPS messages are arriving at regular 200ms intervals as they should.
                    A correction to the 3rd point.  I checked with our GPS maintainer, Michael DuBreuil, and as Josh Welsh says, the baud rate is being set back to 38400 so it won't help to change that with u-center.  Sorry!
                    Michael also suggested that Paul Atkin may want to disable SBAS (i.e. set GPS_GNSS_MODE to "1") because based on you location you could be picking up a WAAS satellite from very far away.
                    Josh,
                    The GPS driver starts at 38400 but it does try various baud rates if it doesn't find a GPS.  I've never tried it myself to be sure but Tridge and Michael DuBreuil who know more about the GPS driver tell me this.
                  • Hey Randy,
                    I thought on boot, the autopilot was setting the gps's baud rate back to 38400, regardless of what was already set via uCenter.  Is that not accurate? I'm very likely mistaken, but don't know how to read the code well enough to verify on my own.
                    Josh
                  • Randy,
                    Thanks for this information, i will try to experiment with ucenter.
                    As of disabling second GPS it is not a real solution and i still believe firmly proper design requires full redundancy of all critical navigational systems and current code tries to implement it, it only needs some additional finesse to be crafted to smooth up transitions.
      Mark and Wes are correct. It is best practice to leave a reserve. The reason for leaning forward is likely due to the fact that your vehicle is a bit nose heavy. The motors are rated in kv/volt, so as the batteries near depletion you may be able to deliver the amps, but you won't get anymore RPMs. I can't look at the log on my phone, but I suspect rcout for the front motors is at max and that isn't enough to keep you stable so it begins to drift forward. What you really need to know is what voltage you start to lose control, then set fail safe at a healthy margin above that (maybe 0.3v). Your flights might not be as long, but you will be safe. Don't forget also that the performance of the battery will change with time and from battery to battery. It's just safer (and better for your batteries) to leve a healthy reserve.
      Nathaniel ~KD2DEY
    • If the battery fail safe is set to low, you may not have enough power to make a controlled landing. I made this mistake once trying to test max flight time. The voltage dropped to low and the quad nearly fell out of the sky.
      I would suspect that you did not have enough power for the quad to respond to your inputs as shown in the difference between the desired input and what actually happened.
      I have destroyed enough lipoly battery packs to give up on max flight time. I land at 3.5v per cell and have set a new goal of determining the max usable flight time landing with a 20% reserve, just as is recommended by nearly every manufacturer. Now my batteries last a long time and my quads receives a lot less damage.
      • Another aspect that should be considered as far as the reserve you set is the altitude you usually fly AND check the max decent rate. If the MR goes into FS and tries to land itself it can literally run out of juice just coming down so darn slow. I think the default is very slow for safety but might want to increase this. I think another thing that can happen as well is if the pilot is not be fully aware of what’s going on, especially if the ‘nudge’ option is on, so the pilot see’s he has some control of the pitch and roll decent but NOT the rate it’s dropping right? [The ’nudge’ option doesn’t effect decent rate with pilot throttle input does it?]  So one might be watching his copter about to land in a tree and not realize it’s in the ‘land’ FS mode and just goes full throttle but unless I’m remembering wrong that won’t work unless he toggles the mode switch to get out of FS. An extension ladder and a flashlight was involved in my learning curve on this. Sorry… OT of the OT… opps.
      • What really strange to me is that "pitch" actually follows nicely with the "desPitch" as you can see from the plot.
        It is the "desPitch" diverges from the "RC2" input. Why this can happen? Doesn't "desPitch" take input from "RC2"?
        Thanks all for the advices. I will surely follow the 80% battery capacity rule ^^
      •  max usable flight time landing with a 20% reserve, just as is recommended by nearly every manufacturer.
        I've used several types of lipo and NONE of them recommend leaving a mah reserve, ie only using 4000ma from a 5000ma battery.
        They ALL recommend only using 80% of the maximum amp capacity, ie a 5000mah 20c lipo can deliver 100amps so you only pull 80amps from the pack under full load.
