Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
yeah maybe. Are you just running it bare on the frame? I originally chose the rctimer based on the case. You're right, it might be equivalent, but it wouldn't hurt to do a comparison.
It's got a grounded copper disk under it..
I've got a photo in another thread.. let me see if the link works here..
Not that I've noticed. I wouldn't expect it to, but I have not done any A/B comparisons. Many GPS units have that copper layer built in to the PCB.
In the arudcopter settings, I'm assuming you mean the one that defines 0=unchanged, 1=gps, 2 or 3=gps+sbas, etc, then I'm on 0.
I did try limiting it to only GPS or GPS+SBAS, and I get better results with 0, looking at all available data.
(if you mean something else, let me know)
Edited to say, when the GPS arrived it was set up for Europe's SBAS settings, and I had not good results. When I configured it for north America, it performs great. (I checked my RTFQ gps, and it has the same settings as the current CSG one that's working well, so that wasn't the issue w/ it)
I'm trying to run 3.3rc11 but can't get MP to update to the Beta version properly. When I start MP it says there are Beta updates available. I click yes to start the load and after some initial files I get a permission / 403 error when the resources file is uploading.
With my airframe updated to 3.3.rc11 and this partial MP upgrade the parameters are all screwed and any attempt at flight ends in immediate disaster!
yea i have a micro pixhawk called pixfalcon micro from hobby king on a 250 i uploaded rc11 and everything went nuts on mission planner the horizon thing was spinning around in circles everything was on acid... went back to 3.2.1 everything was fine weird.. rc11 3.3 is just well nuts
I have deinstalled MP and re-installed ( running the MSI as administrator with a registry tweak ) trying to get the beta releases I still get a 403 from the servers when trying to download the update. Can anyone point me to the beta builds of the files that I can use or a list of files that comprise the beta upgrades.
Captain,
hell of a lot of nuts around...
I am pretty sure that AC3.3rc11 is not to blame if AC 3.2.1 is running fine. Your copter should fly better with AC3.3rc11
But, have you gone through all the calibration steps again?
Best regards,
Thorsten
um no rc11 is to blame.. didnt do it on 3.2.1 the official release.. when i went back it was fine so it was the beta... dont forget im a captain and been flying helis for 20years now.. but this new tech is all software based.. to many sensors to many things to mess up.. before you had to actually know how to fly with this stuff its point and click..
James,
Where exactly do you think AC 3.2.1 came from, another planet perhaps? It came from the same developers working on this release.
What Thorsten was asking you, which by the way you didn't answer, was if you had followed all the directions at the top of the page, you know the ones in bold red type warning you of impending doom if you don't do certain things like re-calibrate your accelerometers when upgrading from AC3.2.1? If you didn't then go back and follow the directions. I think you will find it makes a world of difference.
Live long and prosper,
Nathaniel ~KD2DEY
140
141
142
143
144
of 449 Next
