Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • +1 ; I prefer numbers too
  • WOW!!!!
    Today, a windy day (as usually here) I try Richard recommendation to cover the Pix not to loose altitude, I used a salad bowl and works GREAATTTT!!!!!, It's impressive to watch this copter flying with this wind :O , impressive code too, Many thank's Richard and Dev Team :)  :)  :D
    The only thing I don't feel comfortable with this vers is that if I change from stab to Pos hold and throttle isn't in the middle, the copter loose altitude very fast, that didn't occurs for me in older vers; It's only a detail but a newbie perhaps can crash if surprise him/her. But I don't change this vers for nothing older, It's looks much better for my complicated cuad
    Richard: You can't find a solution for your Tanaris yet? .
    • I've learned very quickly to get the throttle stick centred before switching to Alt Hold! I think a delay on the switch and a centre stick reminder might be good. Time to tinker with my Taranis! :)
    • This reply was deleted.
      • Thank's Kurt, I'm going to play with dead band perhaps solve, I'm going to re-check the mid throtlle in case too.
        This disposable salad bowl is very similar than RcTimer one, fix perfect on my cuad and is very light....now I'm dieting to have more domes ;)3702722296?profile=original......perhaps looks horrible but I'm so happy than I look nice :D
          • Good idea, Thank's
    Hi Trent,
    An overheated ESC would definitely fit the bill!!! That would explain why you didn't loose all power. Being your first flight going that long and with extra weight all makes sense.
    As you said, that flight doesn't show any signs of the same problem.
    Good luck and let us know if you learn more!!
    • I with you, lidar and PX4flow on the bench...
      Info is still sketchy.
      • Tested my height following with lidar today. Passing close over my car ( noooooooo ) and even over me and it works beautifully. My only comment is that we need some indication of what is in charge of height,  ( as opposed to altitude ). An indicator on the GCS that the vehicle is height controlled ( sonar/Lidar ) as opposed to altitude ( Baro/GPS )  would be nice. Perhaps even an added channel control to follow sonar/lidar - terrain following?
        copter 3.4 anyone?
    3702597234?profile=original
    Hi Trent,
    It is very clear from your log that you lost motor/esc 4. I can see from your log that this happened very quickly but it also didn't stop fully so you may have burnt out some windings on your motor. Based on the fact you didn't lose the thrust completely I suspect you don't have a problem with your wiring. You may have lost some of your fets in the esc. You may also have a prop loose or broken (but I suspect you would have seen that). Problem is you should have seen all this in your next flight.
    The only other thing that may have caused this is noise on your signal line connecting your pixhawk to the esc. I have had this problem on my high powered quad and had to make sure I didn't run the ESC servo wire next to the power wires.
    The only good news is this isn't the autopilot, it is something between the output of the pixhawk to the esc, the battery, to the prop.
    This one is a head scratcher. Sorry I can't help more!!
    I also tried to download the log and could not becomes of a permission problem.
