Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      IvanR,
      Thanks for the report.  That really does look pretty terrible with the vehicle oscillating quickly in roll and pitch at a couple of times in the flight.  I suspect reducing the WPNAV_ACCEL to 100 will help but it's current value of 200 doesn't seem high enough to cause this problem.  I'll have a chat with Leonard about this and get back to you.
    • didnt attach log, here it is
      2015-08-31 11-39-37.zip
  • Hi Randy, loaded RC10 on my Y6 with U8's running 28 inch props, flew very nice over 3.2.1.  I especially liked the smooth throttle handling on Loiter take off and landing. Will conduct autotune tomorrow.
    I notice that RC9 now has support for Lidar Lite V2, does this mean we can now connect the V2 via I2C?
      GocGoc,
      Thanks for testing.  Tridge and TomP have been testing the lidar-lite and he I2C reliability of the V2 seems better than the previous version.  They've still seen situations though where the sensor is suddenly reporting a 13m offset from it's actual distance.  The cause & fix aren't clear yet, but it seems voltage related and the issue is certainly within the sensor itself.  Basically, I guess I'm saying, we have a driver for the V2, you're welcome to try it out and we'd appreciate your feedback to see if it matches what we've seen.
      • Hey Randy,
        I've been testing the V2 via PWM connected to the Pixhawk (using master branch). I also see the jump, often to 12.02m. I also see the PX4Flow Sonar jumping to 12.02m.
        Did you guys also see the jump via I2C, or only via PWM?
  • I have NO idea why this doubled posted. Sorry.
    • ack page freaked out so here is the log file.
      2015-08-31 01-13-56 1.bin
        The throttle seems to stay at zero for this whole flight so perhaps this is the wrong log file?
        • was the only log file on it :( I'll try again a little later today.
  • Can somebody shed some light on what might be going on with my hex?
    This thing has flown for almost 2 years and has been an absolute joy to fly. But not any more.
    1st symptom: Throttle is like super sluggish. When I give it throttle it like takes its time to actually spool up and takes as much time to spool down. I've calibrated the ESCS a ton of time.
    2nd symptom: I can get it in the air but then all of a sudden it acts like it's in auto tune (2) it pitches forward for no reason, then pitches back for no reason and I have to fight like hell to keep it from crashing.
    I think the attached log is from the few seconds I had it in the air tonight so maybe someone can help me deduce just what is going on.
    I took the FC off my beater quad after having quite a few successful flights, then set all the pids back to default and nothing I change makes it act any different.
