Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm not sure of the HDOP, that is prob in the log, but I usually have 10-13 sats within 10 seconds. Andy, I'm glad yours improved. I will try that and have results soon, too. Thanks for your suggestions.
I agree that 1.3Ghz could be wreaking havoc BUT having just been through this myself I think another highly likely option is the camera and video cable - neither are shielded and on my mini quad they were completely killing the GPS (vtx had no impact but that was on 5.8Ghz). I have what looks like the identical camera and I believe it leaks a lot of RF interference. Likewise the cable. Wrap both in copper tape and and that should make things a lot better. I would not advise putting the GPS above the camera for this reason - you would be better off moving it to the back. If you look at a fat shark camera setup the cables are always screened.
See here:
http://diydrones.com/forum/topics/using-camera-wipes-out-gps-signal...
Just a follow-up on this. Finally got to properly test my camera/cable screening solution (copper tape) and the difference is night and day! Before I was rarely getting a lock after many minutes and even if I did it was 4 sats high HDOP. Afterwards I was getting a lock in < 30s with 10 sats and HDOP 0.8 on an LEA-6H. YMMV as my camera is VERY close to the GPS unit (0.5 cm) but FYI.
A USB software defined radio is a good way of diagnosing interference. They can be had from ebay for $12-16. Then download some scanning software and do a scan from say 1550 to 1600mhz and see if there's anything showing up around 1575 (where gps operates). If you do get interference, disconnect one item at a time (a process of elimination).
Could you please point out a model, make of radio you referring to, or url to one on Ebay, so I can get a ideal of one your talking about.
thanks for the info.
Has it flown successfully? I ask because I make it rule to keep the vtx antenna away from the GPS/compass and pointing down. That looks like a 1.3 ghz and could be wreaking havoc on them.
Yes, definitely antenna at this position jamming both GPS and compass.
Just screw it below the body under the battery. And move the GPS/compass pole at the place of the antenna, just behind the camera. You should keep the sensors away from all antennas.
during your position incident your number of GPS sats suddenly dropped from 13 to 9....this probably caused a shift in position which is visible if you plot GPS.LAT/LONG and POS.LAT/LONG and AHRS.LAT/LONG you clearly see it, its also shown in NTUN desired vs actual position as well (for position, velocity and acceleration, they all show it very well the discrepancy)
Like you I also struggled with a couple crashes with sudden position changes too (one of them dangerous!) , it was frustrating, I eventually replaced the GPS and never had an issue ever again (using M8N now).....not saying is the same problem for you, but just something to think about
Ivan, I think that is exactly what happened, but I didn't know how to verify that theory in the log data. I did not know any GPS units but the uBlox worked with the Pixhawk. I will get an M8N and hope for the best. I think there are other unrelated problems with my Pixhawk, but some further experimentation with Andy's suggestion will prove some of that out, too. Thanks for your info!
Rick
Your log doesn't look overly strange to me. Sure you get a spike in the EKF, but it settles down again and is not massively high. What I don't get is what caused it. GPS/MAG look ok to me. The only thing that is weird is the AccelZ on the IMU's are about 1m/s/s out. There is a drop in GX at about the same time, but not sure whether that is related. If your accel offsets are badly affected by temp you might want to try calibrating at operational temp rather than room temp.
21
22
23
24
25
of 449 Next
