Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
You need to downgrade to AC3.2.1, and then load the custom firmware ac3,3-rc5.
I got several errors before loading the AC3,3-RC5, but I got it.
ArduCopter-v2.px4
thanks! do you happen to have the tricopter version also?
Remember, you know Pixhawk version (v1 or v2).
V2
ArduCopter-v2(tricopter).px4
many thanks!!
thanks. I could downgrade straight from rc6 without a problem
I was flying for a few weeks with rc5 with not surprises so will continue to do so until my crash is well understood.
After 2x15mins problem free flying I crashed with the third battery - some damage; log refers to some sort of gps/ekf problem.
What I saw the roll became absolutely uncontrollable the quad sided did not react to throttle input (hills so tried to gain altitude and do some sort of controlled landing) and crashed (probably land mode due to EKF failsafe). Meanwhile pitch and yaw as absolutely stable/ok - so hard to believe there was a compass or GPS problem. There is nor obvious mechanical problem visible. Furthermore the quad crashed in AltHold/Land mode those are not using gps/compass so I would expect a soft/soft-crash landing not like it happened: hit the ground hard and on the side.
Place is an open field with no known interference, I was flying alone - I flew there many times with no problem so far.
(1) Anyone can help please with some hints what could happen?
(2) why did I have hard and uncontrollable quad in non-GPS/Compass flight mode if it is a compass/gps problem...
(3) EKF failsafe - can I switch it off or change to ALTHold - with low altitude (Lidar altitude reading in the log) like this and unpredictable behaviour actually I did not have the time to take over control quickly enough (also, unfortunately telemetry was not connected to my tablet to hear voice announcements) so auto land is a disaster.
This is the nightmare scenario for me - uncontrollable quad at low altitude.
2015-06-27 15-08-16.log
Hi Guys, thanks for rc6 update.
Autotune seems working pretty good, PID's are about 5%-15% higher. (don't know if this is related)
ATC RP almost same and ATC Y about 25% higher. ATC Y now is there were i set it manually before.
i was having some trouble leveling while first takeoff without GPS. As GPS was gained all went fine.
After updating my APM Planner, I was able to read logs, and found the source of my red/yellow blinking light at launch. It's EKF Variance (err code 16, 2). I get the warning flash for about the first 20 seconds of flight, then it clears. During this time, the copter appears to fly fine in AltHold and Stabilize, but won't switch to a GPS-assisted mode (by design, I know). EKF_CHECK_THRESH is currently 0.8, should I adjust it to something higher? I'm just not sure how to read the log and find out what's causing the EKF variance.
blinking.log.zip
