Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Randy didn't mention it in the release notes, but my PR for this bug was merged and is included in AC3.3rc9 so automatic flow control should be working again now.
          --Brad
        • Randy,
          I had suspected this was a 3.3 only bug and Mark's experience seems to confirm that.
          I'm guessing some timing changes exposed this latent race condition sometime in the 3.3 rc series.  In any case, I'd consider it a regression and perhaps you will want to review this PR prior to the 3.3 release.
          https://github.com/diydrones/ardupilot/pull/2556
          Thanks,
          --Brad
    • Probably not helpful, but my radio telemetry works fine on rc8.
      It's working on telem1 as well as telem2.
      Do you have something else connected in parallel with the telemetry radio with an Y cable?
    • I´ve the teensy working with -rc8
  • Hello Folks,
    since -rc8 was released I´m using it. I´m flying every Day min. 1h. No faults every thing worked very good.
    Only on thing does not response is the "DO_CHANGE_SPEED" command. Just nothing happens! But I´ve to say that I´m using ch6 to change the WP_Speed. My thought is the the DO_CHANGE_SPEED command overrides the WP_Speed and if a new WP_SPEED comes from ch6 it overrides the previus command.
    I would appreciate a "condition_change_speed" AND a "condition_change_VS" (VS=vertical_speed).
      Andre.
      Yes, as you suspect using ch6 to "tune" the wp-speed will overwrite the do-change-speed command.
      There are a couple of to-do items (here, here) on the issues list to allow setting the speed-up/dn but just haven't gotten to it yet.
  • Hi
    My pixhawk accel calibrates fine on 3.2 but refuses on 3.3rc8.  Could this be linked to the acceleration sensitivity being increased?
    Gareth
    • Anyone able to advise on this?
  • Just thought I'd give a shout out to the Dev's of 3.3!  A solid day (so freakin' tired!) of mapping for contours and volumetrics.  My mapping X8 is solid as a rock.  25kph winds and going strait as an arrow.  Still a few issues with the geotagging, but not a bit problem using Pix4d and a 90 degree kappa adjustment.  Best flying mapping drone yet.
  • I have not been able to download log files via Mavlink or even terminal IIRC since day one on PIxhawk. It always pops up "Error receiving log list". I have gotten so used to pulling the sd card out and getting the logs it kind of became normal. Would erasing the sd card and reloading the firmware fix it?
DIY Robocars via Twitter
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
3 hours ago
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
3 hours ago
9 hours ago
Saturday
Saturday
Saturday
Friday
Thursday
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
Jul 4
Jul 4
