Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'll be happy to share logs, if anyone is interested.
I will gladly plug in both GPS units to either the same pixhawk, or two different ones, and log them sitting next to each other.
I've done several tests now, and there is definitely a big difference in performance.
The CSG one was 3x the cost, and I'd say from the past two days results, it is 3x better!
I have no issue paying more for a significantly more effective implementation. It's true all of these have M8N but different antennas, trace/PCB quality, and antennas certainly will make a difference. My question is: what CSG board are you using? Is there one that is either in a case like the 3DR/rctimer/etc. or have you found a case that works? All that I have seen are bare boards. DIY is fine for one-offs but I need something repeatable for research craft.
Personally all I have ever used is the rctimer M8N and it has seemed fine for me, but I wouldn't mind an improvement if the CSG boards provide that.
Cheers!
http://www.csgshop.com/product.php?id_product=173
http://www.drotek.fr/shop/en/home/613-ublox-neo-m8n-gps-hmc5983-com...
http://www.goodluckbuy.com/5050-standard-plastic-protective-shell-c...
I tried several cheapo boards with M8N, but some of them performed even worse than the good old 3DR LEA V1.1,V1.2...so won´t use them for expensive rigs . But for those who even use the PX Lite on a low cost setup they maybe even good enough .
@gervais
It is great to see that CSG shop, and Drotek provide "Quality implementation" of the M8N GPS.
Drotek M8N, CSG M8N without large disk, CSG M8N with EMI protection, CSG M8N other version
Exeptional linear voltage regulator with more than 55 dB noise rejection (10Hz to 10MHz) and output noise of 4.17 microvolts rms maximum!
You can get these amazing little regulator boards here: Voltage Regulators
The GPS will have no reason to "behave badly" due to noisy power lines :-)
It is now up to everybody to decide if they want to "gamble" and use some "el cheapo GPS board" with "disastrous noise" on the GPS's power lines.
There is a good switching noise blocker from Micrel:
Another way to stop the switching noises from your "switching voltage regulator".
Micrel_Ripple_Blocker.pdf
@crayfellow
I have never used the rctimer GPS.
However I have used three different implementations from CSG M8N.
One thing worth mentioning is that I always power the CSG units, and the others, with a noise free 5 volts power.
(Certainly not a switching line carrying added noise from ESCs) :-)
I took care of insulating the GPS from radiated EMI noise as well.
The best I got of the three is CSG M8N and compass The second best I think would be this one: CSG M8N medium with compass
I used other GPS such as LEA6H, neo7 and many more. For whatever reason(s) the ones I mentionned above (see links) are doing a fantastic job for me.
Cheers
Henri
I have 5 different "budget" m8n's and they all perform fine for me. True I always fly in the open, I never take off until I get max sats [usually from 18 to 20] and the lowest HDOP. The RTFQ mini works GREAT on my 250, a BeStar that started out HORRIBLE now works the best out of all of mine on my beater 300 woody and 2 that are in pucks work great on my 800 hex [it's the ONLY thing working great on that bird right now :(] and one on my 800 X8. If I could afford one of the CSG boards I would get one to test against my other units but I have so many other things I want/need to buy that it is really low on my list :)
The bad AHRS shouldn't come from the GPS but it can be caused by the EKF being unhappy with the compass, accels or gyro values. Maybe have a peek at the live EKF viewer in mission planner or Tower?
For the M8 GPS Marco's recommended config can be found here.
You can just remove the TX lead from the flight controller going to the RX lead on the GPS and it will not overwrite the GPS's prom on power up. Do your testing and if you find it no better, then just put the lead back on and let Ardupilot do its thing :)
i don't remember much from using U-Center under wine but perhaps you're not saving to EEPROM and the coin battery in the GPS is missing or dead? There were at least 4 options to choose where to save to on the GPS.
I can't say anything about rctimers.. Maybe it's fine?
I'm using the mini csg, dual band unit...
http://www.csgshop.com/product.php?id_product=185
So, it's basically the same form factor as the RTFQ GPS.
I've also got an HK one, which was similar in price to the CSG one. Its performance seems to fall somewhere between them.. not quite as good as CSG shop, but I have not done any A/B comparisons with them... I haven't used the HK one for a while..
139
140
141
142
143
of 449 Next
