Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
thanks I'll give it try.
Hey, a bit off topic, but could not find another place where this might be noticed by correct people (do not know who exactly):
Antenna tracking firmware for apm/pixhawk is lacking support of continuous rotation servos. I understand why there was no such support with the MP based tracker, but since we have IMU on the physical antenna, I think it should be farely easy to add support for continuous rotation pan servo. It is so easy to turn almost ANY servo into a continuous rotation one by immobilizing potentiometer in the middle position inside servo with some glue.
anyone know what the "Z" column in the vibration sub-screen is measuring? that column for me is a bit higher than the others during flight so I'd like to know what to look for. it is not steadily higher, just jumps up higher sometimes into clipping rather regularly.
Kurt,
Quite often you can reduce the Z axis vibration level by reducing the amount of bell play in your motor housing. As your props load and unload in flight the changing load on your motor causes the housing to jump up and down within the "play" on the shaft. You can reduce this by using a special clamp to compress the housing on the shaft, reducing the amount of excess bell play. The more bell play the greater the vibration as the housing jumps back and forth between the limits. The trick is eliminating the excess without inducing friction or drag on the motor.
Myself and others have seen dramatic reductions in Z axis vibration by eliminating this excess bell play.
Nathaniel ~KD2DEY
Excellent info thank you. I have the RC Timer 5010 360KV motors w/ 1755 RC Timer CF props. the motors have a 5mm shaft that is through a bearing on the bottom of motor and secured with the typical C clip. There is not much shaft tail below the C clip- what type of special clamp are you using, I would appreciate any links and detail. when i mess with the motor by hand there is not really any play felt. but of course the motors in flight are exerting much more direct vertical force. Now that I know what it is, I can look for the events in my logs and correlate them to vertical events.
my other two axis columns are very low, and rather well behaved :D
edit - thinking further, could this be caused by arms flexing?
Kurt,
I can't take credit for the idea, someone here led me to the same information, paying it forward as they say! If you can't feel any additional end play, then it probably isn't a major contributor. Still worth looking at, but not likely to help a lot unless you can feel some end play.
As far as what the clamp looks like, it's fairly simple and from what I've seen, usually home made. The basic construction is usually a section of square steel tubing large enough to encompass the motor. A hole is drilled and tapped in the top center and a bolt is threaded in that location such that when a motor is inserted the bolt can press on the shaft. Opposite the bolt a clearance hole is drilled for the end of the shaft on the other side. There is usually a grub screw on the bell that secures the bell to the shaft. Once this is loosened you can compress the shaft and the bell housing together.
I'm not sure where the original thread is but I'll look around and see if I can find it. I think it was Leonard who originally posted the fix in this thread.
Yes, Arms flexing could definitely cause Z axis vibrations.
Nathaniel ~KD2DEY
thanks for taking the time to type all of that :D - I will look into it.
I'm seeing quite a bit of flexibility in the RCTimer F450/F550 extended length arms. so my first thought here is the arms are probably playing a roll in this Z vibration. they are durable as heck though, and cheap, so it makes for a good test platform. I think my next step will be to swap out for CF tubes and the F450 frame adapters / motor adapters. have to see what the weight differences are though since the adapters are aluminum.
thanks Paul-
