Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi John,
      When the safety button is solid there is nothing being sent to the esc's. I bet if you pull the esc out of the pixhawk while everything is powered up you will see the same thing. This is what your ESC does and has nothing to do with the pixhawk.
    • what do you mean goes into breaking mode? Whenever you remove power from the ESCS/motors they will get "stiff" for a while until all the caps release their charge. This has been this way for well as long as brushless escs came out with caps on them.
      • Well about 18 or so multi rotor builds over last 6 years and I find they don't all do this my friend. It doesn't happen with my NAZE32, APMs, Openpilot Revo, DJIs and so on. I have only had this happen one time ages ago, but cant remember now why and which FC it was and then how I fixed it.
        If what you say should be true, it should happen in every case then?  So then why doesn't it happen if I unplug the battery when it is "armed"?   Yet when it is put into safe mode the motors go "stiff" after 5 seconds and then stay stiff after I unplug the battery.
        I would assume if the caps are doing this then they would do it constantly armed or disarmed? Why is it that when armed they are not and when disarmed and put back into safe mode, after 5 seconds they go stiff again? I would have assumed once put into safe mode, nothing should be going to the motors or the ESCs caps? Yet they are?
        This is a Pixhawk fw issue I think.
        • It has ALWAYS done this on every one of my multirotors. From back when I started using the early miltiwii boards, all the way up to my hawks. Here is a pretty good explanation why.
          • Then obviously not all ESCs do this then. The other ESCs I use don't do this on my 800 hex, min quads etc, and the ones I now have are the first time I have used them. Anyway thanks for you input, its now crystal clear.
  • Any update on getting terrain following in the next update?  Is this still on track?  Just curious after having to abort a mission yesterday in a remote location.  Flight started in a bit of a bowl and the intent was to fly the perimeter of a farm about 30 feet above the tree line.   But on the first leg with Iris about 300 yards away heading over rising terrain I didn't like the margins and engaged RTL.  Yes, I know I could sit down with a topo map to plan such a mission but how much simpler it would be if if the waypoint altitudes could be AGL and not relative to takeoff point.  Hoping to see this very useful feature...
    • Just fix a LIDAR to it.
      • So far, LIDAR sensors like LidarliteV2 don't work in auto flight mode.  I do a lot of mapping is areas with 50m trees lol, not so cool when your mission  is at 80m and your vertical data isn't spot on.  It would be nice if you could set a limited minimum distance between unit and ground independent of the AGL you set in Mission Planner.  If you could set say 20m as you safety margin.  Take off and fly the auto mission at say 80m AGL, but if something encroaches into that 20m the autopilot would ascend to whatever altitude that put 20m between it and the object.  After clearing the object it would return to the requested AGL (sensor pretty much useless beyond 40m).  Or just got get a Nvidia Jetson...  So want one of those lol!
        • What I was thinking is that if the GPS database includes elevation (maybe a bad assumption?) that when you load waypoints into Pixhawk you could specify AGL relative to each waypoint instead of relative to takeoff elevation.  Seems that would be far more useful and would streamline mission planning in hilly areas.... no need to break out the topo chart or guestimate.
            Ray,
            What you describe is planned for Copter-3.4.  I have a half-baked development version that uses the terrain database (fed from the google-earth or other mapping services) but it needs a bit more development and lots more testing before it's ready.
