Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Managed to get some testing with both a Hexa and a Quad, both with a clean install of RC12, i.e. running default values. Did calibration of radio and compass at the field on both uneventfully. Did not have opportunity to run auto-tune or even manual tuning.
    Both copters flew admirably well, and a friend that was with me at the flying field and uses PixHawk on planes was overwhelmed by how good both copters flew.
    @Randy . IMHO 3.3 is ready to rock'n'roll. Press the button :)
    Bad note to this is downloading logs using MissionPlanner, that keeps throwing out errors but thank god for MavProxy or even APMPlanner
    Rkd-cNNJPTaW-TW5JNtAuZH6q7ynybPu3MPSR5b8GeG-NnZ4X3OgaUdmX_ysbykxwNCpNbNJaBJPnMgIm44rL5DJJlgtjrbWCbyEGilm5GB3PFhuCpbaPLL65VYiw6ABap-gblOX4UdiFxBWkmUz-mI3s5lUbU3xvEI_I_vLZcvaNJyR4ruP1JnxXDqiHLuDmqOmXLxapEjnH7jHIv44iFiQAaa_GkWDvLdTcl3Gv3EdRlrIbCElbvb5VNQTlhnkMuwewN_8W_34NfqkBPeFh6gWe9ljkhWY9tdggBbQuraf9c0LdcM1i7u-KgQvnkA8BXMzm2f5KncfuUNC2s94iEq3chhsRby0Ak-4hkA8aiu3oCSGwYq2AZJ72TF42cbubzNomP8loojl3Xf6wZIYuMyjPcV5tjqAFRsPvzZtg7vGi37LNHldsVVdKqbIPM-bxY4QQt-yDLE05iUKyf-GGK8A12h3H_2NrUrKyc9I9ZuUCjnN96aT1TyYPoNag_Cgny03zhJLRpxpcP016-_oeQ1ObXEN3Dpnlw96oD9eXdQJ=w1280-h800-no
    X0H2bNlw6CACoAZUAXdBvL-KZ4vOmfdwgl6sGktqm4NY1cguzF_wdCE_roZGYzaGB78k3NToJ5ROyvz9OvlxS0x2jNuRIq0E3yiipvKfToYAhLQl9Y3-NE4LmZDecaXCU0p3L6rNUG3vgQQIKnWN-niaXR3pDMpdHyBmIfi42Q_yGbpImbfMl4t0dHJgvrlyif2WeaPS2rpQzIwRHgMVWLVevWwNXfO4iovlhZw2-HGqVQLiKHuscDaFQYAJ-bskcyENoh038maewdKdeFlo7-LN7ck4smxGDLILYkH8N0pdb1p3QYaa6zrr0SyKNQRX74DDCvk4d0jHeEeWa_Tu2ESRH5PPNPyV-IcTwZpAsv9wXWPLxRn-Fk86twdMcgAtwxvqbLaLM6C5wTLc98SnqQHVxU1woRZcwAGjaRcka_6p-vwqmgYvmtN56EmtzGvJ-J7s9USTrKG2XYPpBo_UUyNvfIenM9xFSgDfIGBHcqo0nucAQjnLtgyjuPQfniWbqsQPL12buoNZe1r8TjvjooYH__PZXnd4P6iHCbmaNk9m=w1280-h800-no
  • Since people have been talking about compass issues, I'll mention an observation..
    My copter seems to get dizzy when I rotate/yaw.
    I can be hovering completely stationary, EKF is all very low, green.  Then I yaw around in a circle, EKF compass goes into the red, and the copter no longer holds a steady position. It circles around a point.
    But, I can yaw again, back in the opposite direction, even just 20 degrees or so, and the EKF mag reading goes back down into the green, and the copter behaves better.    It's somewhat random as far is how much I have to yaw before the issue appears, but yawing around sometimes puts the ekf compass into the red, and yawing back fixes it.
    I didn't notice this issue in previous versions of copter, or even early 3.3 betas..  But then again, the EKF meter wasn't there making it obvious.
    • The EKF is very good at dealing with compass intereference/offset issues but that does not mean they are not there. You almost certainly have issues with the compass calibration or with interference. I have found that the live EKF viewer is a fantastic way to determine which. Simply connect your copter to USB power and wave it around. The EKF mag should never go above 0.5 (green). If it does then you should recalibrate. If it does not but it does in flight then you have interference (or vibration) issues - you should run compassmot or move the compass (and check vibration). There is also a small but non-negligable possibility that you have bad gyros, so worth checking those if the others do not give you the results you want.
      [Weirdly I can get an EKF spike if I point the nose sharply straight up, but no-where else (not even upside-down). I suspect this is an artifact of the vertical mag field where I live, but would be interested to know a more informed scientific opinion on this!]
      • Good simple test to do, I'm going to try too, flags help a lot to do it easier, thank's for the tip Andy
        (my graph is outside on the open field)
      • Thanks, it definitely does it without the motors being powered.. I can rotate it in my hand and it does it.
        But, it's really random.  I'm doing it now.   Powered up, only about a pixel of green showing at the bottom of the EKF compass meter.  I rotated it 180deg, and it went all orange.  It slowly dropped back into the green over a minute or so.  Now I'm rotating it around in the exact same spot, and it's staying in the bottom 1/2 of the green.
        Well, I'm not asking for help, so I'll drop the subject.. I just wanted to mention it, in case it was an issue or other people were having the same thing happen.
        • The issue you methioned happens here with My Autopilot, with Copter V3.3.2, the EKF status of compass just goes red on my desk when I just rotate the autopilot by 90degrees.
          Have you resolved this issue yet?
          • Make sure you have your compass orientation set properly. At some point in AC releasese devs changed default compass orientations, so what it usd to be roll_180 now is orientation_none.
        • With good calibration I cannot get it above 0.5 even when turning it quickly. If it happens when you turn it slowly then something is up - either calibration or local interference. Hard iron and computers are bad - but you only have to be a meter away or so for this not to matter much.
          What FC do you have, have you run compass mot?
        • Are you doing this indoors anywhere near say a PC or speakers or anything else large and metallic?
          Does it do so outside when you're not around anything such as a car or anything else metallic?
          • It does it when I'm up in the air, so it's not a metal object causing it.
            I have done a compass mot, and I have recalibrated several times.
            It's an auav-x2, with external gps/compass (currently, csgshop).
            But, sounds like others aren't having the same issue.  So like I said, I'll stop talking about it here in the beta section.
            I probably just need to drive somewhere else to calibrate..  Every room in my house has speakers. (I build hi-fi amps as another hobby.)  My yard has metal sheds and porches.  Mostly aluminum, but some iron poles.
            Sounds like these could be causing some calibration issues.
            Thanks Andy and Craig.
