Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Do you have a log? That'll tell you what the warning is.
I'm able to extract the log, but I get this when I try to load it in APM Planner to look at it:
Error preparing inserttable: insert or replace into 'GRAW' (idx,"TimeMS","WkMS","Week","numSV","sv","cpMes","prMes","doMes","mesQI","cno","lli") values (?,?,?,?,?,?,?,?,?,?,?,?); Error is: table GRAW has no column named cpMes Unable to execute statement
If you get corrupted logs over mavlink then pop out the SD card and read directly onto your computer
I'm getting this as well...
So if you're getting EKF variance messages you're pretty much done with 3.3 until it's fixed? Reason I'm asking and I know it's beta, but the autotune works so well! After autotune in 3.3, none of my big units have ever flown this well. Before I didn't even bother with autotune and they were flying like crack addict squirrels lol! But all the muti's are used for mapping. If I'm half an hour into a scan and I get dropped out of Auto mode that would be lame. I presume that's what going to happen with the EKF variance problem? Can I autotune in 3.3 and copy to back to 3.21? Or are the gains weighted differently. Anyhow, great job on the autotune!
Hi Shaun,
Thanks, I am glad you are enjoying autotune!! rc6 is a little better still.
The big difference between 3.2 and 3.3 is the yaw controller. I have added filtering in there to handle the physics of copters properly.
I can't really answer your EKF question but you should be able to apply your roll and pitch autotune results to 3.2. There are a couple of changes that may make them a little less than perfect but I am not sure.
Hi Leonard!
I low aggr tune and stab yaw is upper.
When released rc6?
Hi Aleksey,
I am not sure what you are telling me with your tuning results. If you have a problem could you also provide a tuning log.
RC6 should be out by the weekend.
I'm a latecomer to beta testing v3.3.
I've had many successful flights with v3.2 but with v3.3rc5 I often cannot get it to arm. APM Planner says it needs a "3D Fix", yet I have 8 or more satellites and hdop of 1.6 - 1.9. I've even cranked up the HDOP threshold to 400 (i.e., 4.00)
First thing this morning I did get it to arm (after quite some time) so I successfully did the autotune process. After landing I changed the battery and tried to do another flight but couldn't get it to arm. I've had "prearm chk mask" = 1 (everything) so I tried to exclude only the GPS check but APM Planner doesn't seem to let me upload a number greater than "127" (and unsigned char??).
Could the "Need 3D Fix" message be generated by the failure of something else beside the GPS? I'm using a HKPilot32 (Pixhawk clone) with Ublox M8N gps on a F450 frame.
Can anyone shed some light on this?
I like 2.4 for video and ended up using channel 2505, trying different antennas and maximizing separation until the GPS stopped complaining.
