Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Just ignore this post. OMG, not getting enough sleep! I'm sure you can guess what I forgot to do lol!
Safety switch? :) Been there done that :)
Disable it to hell, so annoying :)
BTW, check the other outputs other than 1-8 and they're all good. Just 1-8 is dead.
Hi Swift,
You can use a X or a H frame type depending on the direction you would like your motors to spin. If you have any twist in your frame at all you will get significantly better yaw performance if you use a H frame setup. That diagram you show is attempting to tell you you should use an X configuration if you have a layout like the copter on the left of that diagram.
To complete my tests of 3.1.2 to 3.2.1 to 3.3-rc10's Auto tune I need a little help with 3.3-rc10
3.1.2 took about 3 minutes so 1 battery is fine. 3.2.1 took about 8 minutes so one battery barely made it. Now 3.3-rc10 is going to take even longer and my beater quad only gets about 10 minutes on a battery so I need a little run down on how to do it on 3.3-rc10. I know you can set a bitmask to only perform part of the test but my question [which I asked about 100 pages back] is how do I know that particular part of the test is complete and do I do the same as before which is once it is complete I turn off auto tune, switch to stab, then land and disarm. Is it the same now? Will it just stop doing the dance so I know that part is complete and then I do the same then switch the bitmask for the rest of the tests and repeat?
Hi Craig,
Set Autotune_Axis to 1 for roll, 2 for pitch and 4 for yaw.
Run through it normally, the copter should stop twitching and give you a tone to let you know you have finished.
You should never have turned off Autotune as that means your values aren't saved.
When Autotune finishes, simply land without changing mode at all or switch to Stabilize and land. Only after you disarm should you turn Autotune off. You can then carefully take off to test your tune of that axis. You can then change batteries and your axis to tune and repeat.
Thanks. I've always done as I said though and it has always saved the new pids. But I will leave AT enabled and land and disarm as that is your recommendation.
What is the bitmask if I want to do say pitch and roll in one shot and then yaw on the 2nd lipo?
Hi Craig,
That would be 3 and then 4.
Hi Leonard. Can you check my post on Autotune a couple of pages ago? I think we can get good info from you. Thanks!
183
184
185
186
187
of 449 Next
