Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • MR60
      A shot in the dark maybe but this kind of unstable behaviour could be due to a too soft anti vibration/ dampening of Pixhawk. How is your Pixhawk held on the frame?
      • On the mount like that:3702725994?profile=originalNot sure whether it's too soft. What do you think?
        • Those dampers look way too close-set to me.  It will cause the controller to wobble and definitely cause problems.
          • 3702853644?profile=original
            Thanks for your reply.
            I use only bottom plate of the mount posted above - another set of holes for dampers are in the carbon frame's plate itself. They are about 45x45mm. It's definitely not a pixhawk size, although it used to work on AC 3.2. Could it be an issue on AC 3.3?
            • Did you look at the EKF while it was in the air?  At first glance the vibration levels don't look bad despite the clipping, so maybe the following is a waste of time, but is my experience with knocking vibration down. However, I would think with your setup hard movements could cause wobbling and weird IMU behavior. OTOH I could be totally wrong.
              On a quad with not a lot of real estate to mount stuff, I ended up doing this, which resulted in very low VIBE levels. It has a AUAV-X2 secured with 3m tape, but has had a Pixhawk. Another thing is 4 10-12mm squares at the outer corners seem to isolate vibrate best. HK Orange Latex is very good and you get a lot for <$2. I think it may even work better than the 3DR foam which isn't available now. Rubberized cement holds well.
              I also found that mounting plates that look like swiss cheese do not bode well. On this copter was glued a thin piece of aluminum plate to give a solid surface on a pretty flimsy CF plate with lots of holes. Without that vibrations were marginal. With it, nearly nothing. Rarely do I mount directly to the top plate unless it is solid. The Pixhack is a nice product btw.
              On this one with a Pixhawk I used 4 Plexiglas pieces mounted on the top plate using 3M 10lb tape. It's thick and helped isolate vibration. This picture was taken when it had 3DR foam, but now has the HK latex.
      Hi John,
      sorry to see your crash!!
      Can you please provide a log of the flip and a couple of photos of your copter.
      This is how you need to tune your copter.
      Reduce Rate P, I, and D by 25% at a time, from defaults, until your copter is stable.
      Increase Rate D until you start to see oscillations.
      Reduce Rate D until you don't see oscillations
      Increase Rate P until you see oscillations
      Decrease Rate P until you see oscillations
      Set Rate I equal to P
      Check to make sure your copter is stable when quickly rolled and pitched to 45 degrees and the stick is let go. Don't hold the stick to build up speed, this test should be done as quickly as possible.
      If the copter passes this test perform Autotune on each axis.
      • Logs: http://1drv.ms/1MPxlJ5
        First file - P value tuning. Second one - more about I value tuning.
        Photo: http://1drv.ms/1PuM8I2
        The only difference is that GPS is put on stick now (the same location, but on stick).
          Hi John,
          I would suggest changing
           INS_GYRO_FILTER to 40
          and
          RATE_ROL_FILT_HZ to 40
          RATE_PIT_FILT_HZ to 40
          Let us know how you go.
          • Thank you for your help, I'll try to apply the strategy that you proposed.
            Just a quick question. What did you mean by the following?
            Should the quad withstand when I do the same but speed it up significantly first?
  • So much has changed since 3.1.5 and I forgot so much since 3.2.1
    I'm sure it's been discussed and answered over and over, BUT, if after Auto Tune the copter seems to not hold well in slightly windy conditions, should AUTOTUNE_AGGR be increased or decreased. I did it at .07.
